Dunno if this is in the right section but I thought someone might be remotely interested:
This is what has consumed me for the past few years...
1984 MA61 Toyota Supra
1988 Supra Turbo engine conversion (7M-GTE w/ highflowed turbo @ 13psi, 550cc injectors, 2.5" flowed intercooler piping, Apexi SAFC2, 600x300x76mm intercooler, 3" cold air intake into guard)
Standard W58 5 speed w/ heavy duty clutch and flywheel
Truetrac LSD 3.9:1 ratio (looking to go to 3.5:1, 3.9 is way to short)
326mm Brembo front rotors w/ 4 piston calipers, 308mm front rotors w/ twin piston calipers
17x7.5" BSA rims, with Toyo Proxes T1R rubber
tokico shocks F&R
king springs F&R
whiteline adjustable swaybars F&R
RA60 front strut tubes (easy 2 deg negative camber)
Everything else has been reconditioned/replaced over the years... except the gearbox I think!
Black Interior swap from other MA61 Supra
Full respray and rust cut out in Black
And more stuff but it's pretty boring...
Also featured:
http://grandjdm.com/2007/10/12/featured-ca...rys-mkii-supra/
Everything engineered and legal. Does winton is around 1:47 but it was my first time on street tyres, I reckon I can get quicker with non-warped rotors :P. Also made 227rwkW at 12psi and 630Nm in 4th gear (equates to around 500Nm at engine).
Really hate the untasteful cars around nowdays, the aim was to create something that fit in the 80s but improved on every mechanical aspect. Stock power is around 138hp at the fly (SOHC 2.8 six), now making around 400hp at the flywheel (DOHC 3.0 turbo 6).
Handles very well, considering it was conceived as more of a big GT than sportscar (I've certainly turned that around). With the new tyres, LSD and neg camber I couldn't get it to understeer in a motorkhana :D
Doesn't have the solid "stuck to the road" feel of the GTR but almost feels lighter and edgier... dunno :blink:
I've got some R-Specs and a Haltech ecu there waiting for some funds to finish the car off. Hopefully with a bit of ignition control I can see 250rwkW.
When I bought it:
Now:
Anyway thats it! I've got an old V8 merc too that gets 20l/100km which is a pain in the arse
https://www.sau.com.au/forums/topic/235493-the-gt-rs-shedmate/
cheers guys. yeah it's a very different machine to the GTR, lots of fun though. Got any pics of your JZA80 N1GTR?
As for knight rider, i was bored and used my phone video editor to make a montage of clips of it to the knight rider theme... i thought it was amusing :cool:
as for pics of the merc, don't have many yet. it's a bog stock 1982 380SE in gold, with a lot of structural rust and 20l/100km. it's a south african one though, so it goes a lot harder than the aussie ones (no pollution crap, did the 1/4 in 15.8!!! :down:)
there are a few vids of it on my youtube channel, username ryleyma61...
thanks again :rant:
Edited by RyleyMA61
  • 3 weeks later...
thanks guys!
yeah it's devils kitchen...
many short videos can be found here:
http://www.youtube.com/user/RyleyMA61
just search for supra under there ;)
it's still costing me money, gotta get myself an oil cooler now!! only thing is the 7M just doesn't have the manic howl of the RB26... :( more of a meaty vaccuum cleaner :(
but it is a hell of a lot of good fun to drive, pretty light and very nice chassis balance... springs are a little soft, which i will fix, and i'm going to try and adapt an RB26 strut brace to fit the supra :bunny:
haha
cheers,
ryley :yes:
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
