Yesterday went to Turbotune in Adelaide to fix a spluttering problem my car has had for a while. Thought it could be either a fuel pump problem or a coilpack. After an hour and some tests, ended up being a faulty coil pack. So happy to get that fixed coz it was driving me crazy. Then we dynoed it and I was shocked to see 201.2rwkw. Only mods are dump/front pipe, hks cat back, fmic, no boost controller but there was a boost increase to around 11.5psi. I was wondering if anybody made similar sort of power with or without boost controller. Will put picture of dyno when I get a chance to scan.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/
  • Replies 54
to me that dyno is reading a wee bit too high
i had my car dynoed at Willall Racing and they use a mainline dyno
with a front mount, boost increase to 9psi, full zorst, splitfire coilpacks, pod....my car made 188.7 rwkw on a reasonably warm day
so from the mods that you are saying you have i would expect the same sort of power that my car has pulled out
plus no boost controller and ur hitting 11.5psi....umm have you had that reading out off a boost gague or from the stock gauge.
Edited by Krishy
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123368
damo had 2 dyno results from 2 different places.....
autosalon dyno if i remember correctly he made 161 something rwkw
and at southern hi tech dyno he made 184.2rwkw
that alone tells you that every dyno is different
Edited by Krishy
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123473
You WOULD have about 200rwkw if there was an aftermarket computer or your ecu has been remapped........
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123484
my 33 made 192kw with just a pod and turbo back three inch exhaust. i fitted the FMIC and it automatically pushed the boost up. final result is 205.4kw on 10psi :blink: ... i'm stoked:) oh and im running stock ECU and no boost controller
Edited by IZZMO 33
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123529
Southern Hi Tech: 182.4rwkw
Autosalon: 165rwkw
I got the lighter wheels back on and have a dyno day at graham west next month. im very interested to see what it pulls now, although i may have a few goodies on by then so the comparison wont be that accurate.
At autosalon in 4th it was hitting speed cut on the ctock ecu but hadn't maxed the revs yet, but at southern hi teech it reached max revs, so i guess each dyno is calibrated differently.
Edited by Damo_R34
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123552
same goes here, i achieved quite a boost increase after installing FMIC. Around 12psi. no aftermarket boost controller, and what appears to be the standard ECU. Same other mods that IZZMO mentioned - pod, turbo back exhaust.
She's running pretty nice.
Next thing i'll be adding is better coil packs - my oem ones are pretty fried.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123577
Mainlines do read lower due to their more accurate correction factors but this is widely know, so you can compare DD figures to DD amd mainline to mainline but can't really compare them against eaach other.
I fitted the exhaust and cooler to this car, there was also some cat "modifications" so the boost increase is due to the increase in the exhaust flow.
The boost reading is off the MAP sensor on the exhaust.
I would say that the figure is pretty accutre due to how i only just pulled away in my lighter 180 which was running about 205kw(14.5psi) at the time when we had a run on the freeway on the way to Mallala (kept it under 110 of course).
As cubes and Jeff said prehaps it's just a freek.
Edited by D_Stirls
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123645
Where there is a boost jump it should only jump to around 9 or 10psi. Most 33's do that with those mods, but I think there are some that just might do crazy things and jump to 11 or 12 psi like mine and I dont know why, maybe just lucky. Plus turbo tune had just finished having they're dyno serviced on monday, so dont think the dyno is a problem.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123646
auto salon was dead on actually. i had just got my car dyno tuned at boost worx a week prior and it made 2kws more than it had been tuned for.
anywho.. i dont find it hard to believe 200. i mean 11.5 is lot of boost for a rb25.
https://www.sau.com.au/forums/topic/235496-dynoed-my-r33/#findComment-4123650
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
