yeah sounds a bit too high, my 34 with exhuast, fmic, ~9psi, pod makes 185rwkw, so id guess on 11psi ish youd be at 185rwkw-190rwkw. how have you achieved that boost increase?
Jeff at turbo tune said something on the lines of the stock solenoid has a high and low setting. Mine started at 6 psi and then made its way up to around 11.5. When I get the dyno sheet scanned you'll see where the boost increase will be.
  • Replies 54
auto salon was dead on actually. i had just got my car dyno tuned at boost worx a week prior and it made 2kws more than it had been tuned for.
anywho.. i dont find it hard to believe 200. i mean 11.5 is lot of boost for a rb25.
The Autosalon dyno was the Graham West dyno, yeah?
correct cronic.
Zak, yeah you've got a real gem of a 33 there, seems your fmic and exhuast is working very nicely with your engine.
And Steve, i was just asking how he achieved the boost increase, a jump to 11.5psi from just minor mods isn't seen too often.
Edited by Damo_R34
yeah i edited that, it came out completely wrong lol. 6psi sounds like a fair gain in boost, i wouldn't mind having mine looked at. Guess i'd start with hi flow/no cat and removing the restrictor.
201 is a too me sounds about right.
i made 205 with the same sorta mods when i had me ebc fitted and set at 11 psi...
got alot more now though :P :P
Edited by craig R33
he wont be able to add it now Dale, you have 10 mins to edit your post unfortunately. Has a nice increase at 150kw's, Jumps to 170!
I think you'll find that that is AFR related. the factory maps are a bit all over the place as they are only tested at certain points in the rev range not over the whole range. So at the points were they are tested they have good emission's and every where else it's tuned for safe power.
Zac has an SAFC II in the car but it hasn't been played with at this stage and has 0 correction factor at every point so when he takes it to Jeff next the AFR's will be more constant and there will be a bit more power (~10kw).
P.S. thanks for letting me know about the editing time, I never could figure out why you could edit your post some time but not others. On NS where I do most of my posting you can edit it any time. I guess it pays to be a post whore on more than one forum.
Edited by D_Stirls
wheres the Dyno settings at the bottom Dale
i thought it was more like 30mins editing either way we need editing rights
I'm not sure where the info is, I just checked the printout and it's not on there.
But I also looked at the printouts for my car that were done on the same dyno and there aren't on there so it might be the way TT have there printouts setup. I would say the the temp are correct because every time I have seen Jeff drive a car on the dyno the first thing he does is enter the humidity and temp from the weather station they have setup next to the dyno.
Ive been in and driven IZZMO 33's car and it feels very much like 200+rwkw with minimal mods aswell..very impressive.
to me that dyno is reading a wee bit too high
i had my car dynoed at Willall Racing and they use a mainline dyno
with a front mount, boost increase to 9psi, full zorst, splitfire coilpacks, pod....my car made 188.7 rwkw on a reasonably warm day
so from the mods that you are saying you have i would expect the same sort of power that my car has pulled out
plus no boost controller and ur hitting 11.5psi....umm have you had that reading out off a boost gague or from the stock gauge.
My R31 with series 1 rb25det and my r33 with series 2 rb25det both made 203rwkw and 205rwkw with 10psi, cooler and exhaust on a few different dyno's give or take 3-5kw
You WOULD have about 200rwkw if there was an aftermarket computer or your ecu has been remapped........
not necessary mate. Every car is different.
over 30 posts and no one has mentioned ramp rates.
how much brake against the rollers.........you need to compare apples for apples
God dam it pete, you beat me to it! hehehe
People dont realise that its up to the dyno operator to choose the specific ramp rate that the dyno produces...this alters your power output...usually a standard ramp rate for these things is around 150.
So many people are quick to assume every car is the same and will make simular power with simular mods. Every car is different. So many variables come into play when it comes to output on a dyno...remember people its just a number.
Edited by Ryanrb25
oh and i forgot to mention we've had plenty of 33's on the dyno at Aussies and alot of them make good power (190-200rwkw) with basic mods yet others make average power (160-180rwkw) with simular mods...SO many variables. Believe it or not other cars have had a much harsher life than others.
Edited by Ryanrb25
and some over 300rwkw Ryan...lol
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
