yeah sounds a bit too high, my 34 with exhuast, fmic, ~9psi, pod makes 185rwkw, so id guess on 11psi ish youd be at 185rwkw-190rwkw. how have you achieved that boost increase?
Jeff at turbo tune said something on the lines of the stock solenoid has a high and low setting. Mine started at 6 psi and then made its way up to around 11.5. When I get the dyno sheet scanned you'll see where the boost increase will be.
  • Replies 54
auto salon was dead on actually. i had just got my car dyno tuned at boost worx a week prior and it made 2kws more than it had been tuned for.
anywho.. i dont find it hard to believe 200. i mean 11.5 is lot of boost for a rb25.
The Autosalon dyno was the Graham West dyno, yeah?
correct cronic.
Zak, yeah you've got a real gem of a 33 there, seems your fmic and exhuast is working very nicely with your engine.
And Steve, i was just asking how he achieved the boost increase, a jump to 11.5psi from just minor mods isn't seen too often.
Edited by Damo_R34
yeah i edited that, it came out completely wrong lol. 6psi sounds like a fair gain in boost, i wouldn't mind having mine looked at. Guess i'd start with hi flow/no cat and removing the restrictor.
201 is a too me sounds about right.
i made 205 with the same sorta mods when i had me ebc fitted and set at 11 psi...
got alot more now though :P :P
Edited by craig R33
he wont be able to add it now Dale, you have 10 mins to edit your post unfortunately. Has a nice increase at 150kw's, Jumps to 170!
I think you'll find that that is AFR related. the factory maps are a bit all over the place as they are only tested at certain points in the rev range not over the whole range. So at the points were they are tested they have good emission's and every where else it's tuned for safe power.
Zac has an SAFC II in the car but it hasn't been played with at this stage and has 0 correction factor at every point so when he takes it to Jeff next the AFR's will be more constant and there will be a bit more power (~10kw).
P.S. thanks for letting me know about the editing time, I never could figure out why you could edit your post some time but not others. On NS where I do most of my posting you can edit it any time. I guess it pays to be a post whore on more than one forum.
Edited by D_Stirls
wheres the Dyno settings at the bottom Dale
i thought it was more like 30mins editing either way we need editing rights
I'm not sure where the info is, I just checked the printout and it's not on there.
But I also looked at the printouts for my car that were done on the same dyno and there aren't on there so it might be the way TT have there printouts setup. I would say the the temp are correct because every time I have seen Jeff drive a car on the dyno the first thing he does is enter the humidity and temp from the weather station they have setup next to the dyno.
Ive been in and driven IZZMO 33's car and it feels very much like 200+rwkw with minimal mods aswell..very impressive.
to me that dyno is reading a wee bit too high
i had my car dynoed at Willall Racing and they use a mainline dyno
with a front mount, boost increase to 9psi, full zorst, splitfire coilpacks, pod....my car made 188.7 rwkw on a reasonably warm day
so from the mods that you are saying you have i would expect the same sort of power that my car has pulled out
plus no boost controller and ur hitting 11.5psi....umm have you had that reading out off a boost gague or from the stock gauge.
My R31 with series 1 rb25det and my r33 with series 2 rb25det both made 203rwkw and 205rwkw with 10psi, cooler and exhaust on a few different dyno's give or take 3-5kw
You WOULD have about 200rwkw if there was an aftermarket computer or your ecu has been remapped........
not necessary mate. Every car is different.
over 30 posts and no one has mentioned ramp rates.
how much brake against the rollers.........you need to compare apples for apples
God dam it pete, you beat me to it! hehehe
People dont realise that its up to the dyno operator to choose the specific ramp rate that the dyno produces...this alters your power output...usually a standard ramp rate for these things is around 150.
So many people are quick to assume every car is the same and will make simular power with simular mods. Every car is different. So many variables come into play when it comes to output on a dyno...remember people its just a number.
Edited by Ryanrb25
oh and i forgot to mention we've had plenty of 33's on the dyno at Aussies and alot of them make good power (190-200rwkw) with basic mods yet others make average power (160-180rwkw) with simular mods...SO many variables. Believe it or not other cars have had a much harsher life than others.
Edited by Ryanrb25
and some over 300rwkw Ryan...lol
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
