SO many variables. Believe it or not other cars have had a much harsher life than others.
Correct........you take 2 cars with identical mods yet one has a fresh motor while the other is lacking compression with crappy plugs and I guarantee a difference of at least 20 or 30kw.
  • Replies 54
How much effect does the ramp rate have on the over all figure. it would be the same difference as doing the run in a lower gear because that is effectively what you are doing by altering the load. I.e. there wouldn't be 10% difference in a 200kw car due to RR more like 2 or 3.
Also this engine had extremely good compression, i posted the figures up in the wasteland when i did the test because I wasn't sure what the range factory range was, but they were all around 169 mark with very little difference between them
Edited by D_Stirls
Actually sorry steve have to jump in here noone's actually said he didn't make the reading there just questioning the equipment they used to get the reading!
comprehension i never once said he didnt make that figure just what were the dyno settings was what i was implying
remember people its just a number.
yeah but to some it seems figures are more important than where their car is at!
i only pulled 185kw with a pfc (got a restricting exhaust) but some how i still manage to be right next to my mates skylines even though they have more power! as long as i feel the result i'm happy
The more power the car has the more dramatic the power difference is going to be when you vary to ramp rate. Ovrtym33's R33 made 325roundaboutrwkw on moderatly high ramp rate which was around 270 i think. Due to the fact we had to dial out alot of wheel spin on the dyno. On a more modest / realistic ramp rate the car would probably make around 340-350rwkw....however the same ramp rate differences on a 200rwkw R33 would be around 10rwkw difference. not too much but enought to make a customer drive out happier lol.
well the car was actually on the dyno to find an ignition fault which turned out to be the No. 2 coil pack. The figure was just a bonus, i told Zac that he wouldn't make 200 until they played with the SAFC but you never know, that's the thing with playing cars.
He's now giving me shit about how much effort i put into my CA to get 16 kw more :) . But I'm only a decent actuator away from 235.
Edited by D_Stirls
Yep, but that's what you get when you try and 18 psi through a 9 psi actuator.
I only put 2mm of preload on it though so I might try a little bit more and see if that works but i suspect it'll just make it spike higher and then drop to the same point. I'll by a 13.8psi actuator and bring that along when it goes on the dyno next.
Edited by D_Stirls
hey im in the same boat, took my car to turbo tune bout 6months back, i hav a fmic, hks cat back, walbro 500hp pump, pod filter and running 11psi flat (earthed out solenoid). My car got a read out of 221.1rwkw. My engine is a bit weird tho you cant run the pod straight off the airflow meter cause my car will just flood up wen hitting boost. i need an extra bit of pipe on the end and then it runs sweet, turbo tune said they hav never encountered a problem like that
dynos are only good for tuning. and bragging rights :P my car made 235rwkw on tilbrooks dyno with standard ecu and turbo running 13 psi.
thats way too high..... since then the car has had a haltech e11v2 installed at boostworx and runs the same boost but made 197 rwkw on boostworx dyno :P .... that being said the car is heaps more responsive and pulls heaps harder.....
Your right that is way to high but that's Tilbrooks dyno for you.
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
