  • Replies 72
im looking into a cheap pressie for the Adults :D
adult presents hey :D gotcha madaz.
santa's lil helper dvd collection downloading as we speak :)
or for the more family friendly, nene's cruise phootage dvd's :D
Kell just spoke to Adelaide city council. They said we have the all clear to put up a bouncy castle, at no charge. :D:D
Yay! Bouncy castle!!!!!!!!!!!!!!!!!!! :O:):D
Kell, you have my email ... can you send me what I need to fill out :D
Edited by RubyRS4
thanx to the 4 people that actually want to go to this party, that nene and i have invested alot of time in already
Its two months away Kel, dont panic yet.
Im unable to come unfortunately, sporting commitments.
ok yes its 2 months away but when we organise something we want it done right so if someone has organised food to feed ????? because only 6 people have replied then you do it.
Nene and i have invested time and a fair bit of money already so if people can stop being so blaze about this and get your order form from us this thing will go smothley.
After all, its all of you that said you wanted this christmas party a while ago so nene and i have done it so show us that your not all just key board warriors and want to be part of something and then maybe we can get a SA club going
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
