Ok Guys, we need to start getting numbers so i can start ordering food and drinks. Kellie and i have already started to buy small bits and pieces for the games ect...
So who is wanting to come to this event??
  • Replies 72
guys please like we wrote in the first post please sms your email details to either me or nene so we can email you the invitation/lunch order form then you need to email it back so we can start organising the food and drinks.
Thanx
C'mon guys don't sit on you hands get your forms in and pay the girls a tribute for trying to put a little sparkle into our dreary lives
ALSO NOTE ALL up and coming SAU event will now hold a $2/ person donation charge to help pay for things for this event that goes for the up and coming SAU dinner and bowling so please be forewarned i will go around collecting arms for the poor
also NOTE that support the club that supports you just ask Matty about SAU's help when he received a undue fine due to some smack tard being a turd at a SAU event
so even if you DONT plan on coming to this Christmas even you wont be relived of paying a donation this may sound harsh but thats life im also guessing as per other events it wont just be open to SAU members feel free to bring +1's BUT we need to know exactly how many +1's would be attending so we don't under cater the event
any monies not spent entirely on this event will be held in the bank until such times as the committee see's fit to hold another FREE BBQ event (event can only be put on FREE if we all chip in $2 @ each SAU event organised)
i have been asked to be a CO-signatory to the SAU bank account so don't think in any way one or 2 people have all the say in the monies collected
thank you for any support received this shall be the event of all events to end the year :down: less maybe a cruise right at the end :cool:
no Ash SAU SA is still an informal club
Pete a smack tard is someone who comes to a skylines dyno day in a celsior and only runs up 140rwkw gets the shits and roars up and down the street being a hero then after being warned does it again when leaving and the police come and almost shut us down
yeah, was about to say, dont go smearing us celsior drivers with that soarer brush :cool:
i probably wont be coming to this, cant see myself being in a job that would allow it by then, but ill still chip in a few dollars cause im rad like that.
So...as i found out as of last night...i am apparently official photographer for this event ;) (No Kellie did not 'ask' me...it was an order lol)
I am soooooo there. :);):P:)
Ill be there nene.
should get jarred n ket to come too.
should be good. especially if my cars of defect.
Have you turned Newzealander on us all of a sudden Craig? Ket??? As opposed to Kat? :banana:
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
