Item: R33 Series II AFM
Condition: Good
Price: $100 plus Next Day Delivery to your door
To Fit: (What car) R33 Series 2 Only
Contact: RJ 0401338134
Comments: Good working Order, Pictures Provided.
https://www.sau.com.au/forums/topic/235550-r33-series-ii-afm-good-condition/
BUMP.
Please guys need this gone.
Perfect Working order Series 2 AFM.
Will send soon as confirmation of payment is recieved.
FREE next day delivery to your door.
You know you want it.
