Am currently building an RB30DET with GT3582R for my Stagea.
Car will be running straight LPG via gasresearch products (twin convertors, 440 throttlebody, CTI etc) For this reason I only need an ECU to control ignition and was hoping to use the standard ECU along with an Apexi Super ITC... HOWEVER I am worried about hitting R&R. Will a single or twin Z32 AFM's fix this problem?
Also can I have the ECU remapped in order to remove the R&R feature, remove the speed limiter & have the rev limiter lifted to a higher RPM??? Would prefer not to use an aftermarket ECU if possible...
Edited by inmate
https://www.sau.com.au/forums/topic/235556-standard-stagea-ecu-avoiding-rr/
I thought about gas injection but chose to stick with GRA for the following reasons:
1. I would need to go duel fuel which would be a compromise in performance/tuning.
2. I don't want a gas tank in the cargo area. It defeats the purpose of owning a wagon.
3. I already have the GRA gear here from my previous ride.
You can avoid R&R with an Apexi SITC and SAFC (or the Jaycar DFA) and a good boost controller such as Jaycar EIBC.
There are at least a couple of guys on this forum who will remap your ECU: Toshi and Dr Drift
A piggyback or any stand alone ECU would suit my needs but would be a waste of money as I do not need any fuel mapping at all. The GRA system has a closed loop injection system which controls gas supply via the standard sensors so spending $1000+ on 1 of the above just to control the ignition is pointless IMO. I have found that I can purchase an ignition only ECU from Microtech although this is not much cheaper than buying a fuel/ignition system OR another option is a 2nd hand Haltech IG5 (they are no longer in production)...
Microtech = approx $950 for ignition only so not very cost effective.
Haltech = approx $500 for ignition only & is as rare as hens teeth.
UPDATE:
I have spoken to Toshi & having the ECU remapped is deffinately a possibility.
If I chose this route I won't need the SITC as he can adjust timing to suit. Hmm decisions, decisions...
Edited by inmate
I am running similar dedicated LPG GRA system to yours on my Stagea (Series II) + SITC, mostly stock.
My CAS is advanced all the way and my SITC settings are:
800 rpm, +15 degrees
2400 rpm, +15 degrees
4000 rpm, +5 degrees
5600 rpm, -7 degrees
7200 rpm, -7 degrees
I don't know exactly what these equate to as total timing advance but it is a lot and the car can still do with more up to 2400 rpm (no sign of detonation at all).
Your tuner will need a lot of time (preferrably on dyno) to get your ignition advance sorted which ever way you go, however the results with dedicated LPG will be startling and well worth the effort!
The SAFC piggy back to minipulate AFM signals + SITC is another way to go to combat R&R.
The RB30DET VL guys on dedicated LPG I know go for the Microtech or Haltech for ignition control (only), but that is because they don't have other options like us, SITC etc.
How flexible is the remap ECU with ignition timing if you wanted to do some minor changes later on?
and will you be able to control your timing curve throughout the rev range (individually) like the SITC if you needed to without taking it to a specialised workshop? Remember you will need a lot of initial advance and then need to take degrees out as you come on boost (even more so with LPG).
Decisions, decisions.
I would be interested in your final decision as I may go down the more modification path in the future.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
    • @PranK, why do we have this restriction? Because photos are the first thing that gets asked of new people on the forums. Do the spam bots post photos if allowed?
    • How do you rate the clutch @joshuaho96? Sometimes I wonder whether it's genuinely very driveable or whether I just feel that way because it cost a good chunk of money. Most recently when seeing the guy at the tyre shop struggle to move the car...
