Sard 700cc Injectors
Brand new, still in plastic wrapping. Suit GTR.
$950
HKS 2835R
Used, has internal wastegate. Bolt on to SR20 exhaust manifold.
$2200
HKS EVC4
Used, comes with wiring loom, solenoid, control unit.
$500
Trust TD06-20G kit
To suit RB20 or RB25 head. Comes with wastegate, stainless steel exhaust manifold, TD06-20g turbo. Used. Will separate.
$3300
RB26 stainless exhaust manifolds
HKS manifolds, to suit T25 flange. Used, comes wrapped in thermal tape.
$1100
HKS split dump pipe
Used stainless steel dump pipe, to suit RB20 or 25 engines. Standard turbo or HKS 25xx series. With pipe to cat.
SOLD
Front mount intercooler
400x250x60? Came from an R32 GTS-T, would suit most cars due to it's size. Used, no leaks.
$500
HKS GT-SS turbos
Pair of brand new GT-SS turbos. T25 flange, kit is for RB26. Comes with gaskets and mounting hardware.
$4000
To fit those injectors into an R33 RB25 you need to use a top feed fuel rail (modify an RB20 one) and install a resistor pack to use the low impendance injectors.
Location is in Sydney, pics can be found here.
Trust TD06-20G kit
$3300
Every RB20 owner needs one :)
If any Syd owners are considering the kit, your welcome to inspect or go for a ride in my car which has the identical setup.
Sorry about the late replies, email here is sometimes quicker. Pete, email me cause your box is full.
Will go and take some pics now and post them.
Originally posted by rb25
thats an EVC3......
Check out the instructions: here .
I'm not any authority on the HKS catalogue, but if there's a publication by them on how to use and install the device and they call it an EVC IV then I guess I will too.....
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
