Sard 700cc Injectors
Brand new, still in plastic wrapping. Suit GTR.
$950
HKS 2835R
Used, has internal wastegate. Bolt on to SR20 exhaust manifold.
$2200
HKS EVC4
Used, comes with wiring loom, solenoid, control unit.
$500
Trust TD06-20G kit
To suit RB20 or RB25 head. Comes with wastegate, stainless steel exhaust manifold, TD06-20g turbo. Used. Will separate.
$3300
RB26 stainless exhaust manifolds
HKS manifolds, to suit T25 flange. Used, comes wrapped in thermal tape.
$1100
HKS split dump pipe
Used stainless steel dump pipe, to suit RB20 or 25 engines. Standard turbo or HKS 25xx series. With pipe to cat.
SOLD
Front mount intercooler
400x250x60? Came from an R32 GTS-T, would suit most cars due to it's size. Used, no leaks.
$500
HKS GT-SS turbos
Pair of brand new GT-SS turbos. T25 flange, kit is for RB26. Comes with gaskets and mounting hardware.
$4000
To fit those injectors into an R33 RB25 you need to use a top feed fuel rail (modify an RB20 one) and install a resistor pack to use the low impendance injectors.
Location is in Sydney, pics can be found here.
Trust TD06-20G kit
$3300
Every RB20 owner needs one :)
If any Syd owners are considering the kit, your welcome to inspect or go for a ride in my car which has the identical setup.
Sorry about the late replies, email here is sometimes quicker. Pete, email me cause your box is full.
Will go and take some pics now and post them.
Originally posted by rb25
thats an EVC3......
Check out the instructions: here .
I'm not any authority on the HKS catalogue, but if there's a publication by them on how to use and install the device and they call it an EVC IV then I guess I will too.....
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
    • I just watched a Hagerty YT vid on the Rocketeer, with the 3L Ford/Jag AJ V6 in it. I am now sold on the idea.
    • I did look at superchargers for a bit, but from looking, and asking around, IRT the cash outlay and power gains, a turbo has multiple advantages on these little 4 pot engines Either way, boost is not on the cards for my little beastie due to legalities and the cost of getting it legal
    • Great fun track and took a while to get on top of it but got down to a 1.04.5  pulling 220kmh down the main straight on my best run   I would say there is another second or two in the car   couple of videos below
    • So tops day with the lads   basically a old sau reunion of old grey tools
