dkonig: I haven't received a deposit on the 2835R yet, despite some interest. To fit it to an SR20 you need to fit a dump pipe and modify the inlet pipe to accomodate the 100mm front housing. You can get a reducer hose for that. Might need to change the banjo fitting on the oil inlet, the water in/out fit up and the oil return does as well.
Raza: The only rating I've seen on Trust turbos was a chart that had the TD06 family between 400 and 450 hp.
To give you guys an idea I have a td06-20g with a 16cm exhaust housing mounted off the stock rb25det manifold. With the stock ecu and no tuning (as you cant tune the stock ecu... aftermarket ecu in 4 weeks and counting :) ) it made 344hp @ wheels on 13 psi. The car must be making somewhere around 450hp @ fly. If doughboy will sell it seperately, I am seriously considering the trust manifold :)
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
