while trying to undo my dump pipe this afternoon the bloody bolt snapped and most of the thread is stuck inside the turbo threaded hole, there is a few millimeters of thread hanging out the turbo end of the whole.....
how can i get this out or who who can do it in sydney for a decent price????
also could i just drill the f**ker out and put a nut and bolt and washers instead????
need help as this is my daily car
cheers
There are companies that specialise in broken stud removals. They come to you. Search in the phone book. If you wanna do it yourself you will need to get an Ezy out as mentioned. If the stud is seized in there it will be a pain to get out. Plenty of penetrant (WD-40), Ezy out, Centre punch, small drill, etc is what you will need to do the job.
I dont think they charge too much to come and do it for you though. Try Thread tech..
Deren
yeah i decided to either find a 90degree drill and just drill the bastard untill its out and probably stuff the thread and use another nut and bolt instead, or pay the guy who does it for a living $140...... probably end up paying the thread nazi his $140.....
to my surprise he knew what the problem was as soon as i told him its a skyline lol
recons he does atleast one a week
if it was my r33, i would have just forgot about it and done the other ones up.
Because i did, and it was leak free for 2 years, its on the side with 3 bolts, so meh the other side has 2 only
that being said, ive never snapped onein anyone elses car because i would wd40 it early because i remember mine lol. if you still have factory turbo your not really stressing your dump pipe gasket
it didnt leak for about the first 40km, but then i could hear it when i drove next to a wall or in a shopping centre, then it soon became noticable when driving in the open....
also i could only get 4 of the 6 on due to the design of the dump pipe and then was told by the makers of the piece to take it off and evenly bolt it back up.....
then as i was trying to unbolt the dump the bolt snapped at the top, i bolted the remaining 5 up and it was leaking the same as before, probably because it was at the top of the dump pipe and there isnt really a another one that could take over its job.... if you know what i mean??????
oh well i guess its a big learning curve for me
  Duncan said:
get someone to do it for you. if you snap the easy out you are in a world of trouble
yep +1 for getting someone to do it. i tried using an ezyout and broke it. also replace all the bolts while ur at it :) bolts are 6 bucks each fron nissan!
WD40 is your friend.... always. If your socket won't let you tighten up all the bolts it will leak, even if it's the centre bolt. Use some washers or a spacer to get clearance for your socket if need be.
The dump pipe bolts you should be able to get from any good exhaust shop. I got like 6 or 8 of them for nothing cause I asked nicely.
Fixxxer
