Hi , I am based in Redcliffe and was wondering if anyone knows where i can can get an RB30 radiator for an 88 nissan skyline. the cars is overheating when driven over 80 mk's an hour and we are assuming it is the radiator but after examening the boards a bit it seems this model has this overheating problem quite often so any help would be greatly appreciated.
contact herb on 0424619944
https://www.sau.com.au/forums/topic/235686-skyline-rb30-radiator/
mate your best bet would to do a search under wreckers in your area,either on the net or the good ol white or yellow pages.But if you are after a second hand item i wouldn't recommend it, best to buy new to save the hassle later on.Sure you aren't having other issues? ie with the old Rb30 they can run into head and head gasket problems with overheating.Try local radiator places for quotes and for recommended analysis of your problem
But remember to check your basic's. have you got coolant/water in your radiator? Have you checked for milky looking oil under your oil filler cap? if so could be blown head gasket.
Hope this helps
