Hi,
ive just recently replaced my RB20DET,i bought a long engine
since putting it in the front 3 cylinders wont fire, the coils etc. worked fine on the last engine.
ive replaced coilpacks, plugs, and the coil loom
but there doesnt seem to be anything getting to the front 3,
i have also swapped a front plug to a back coilpack to make sure,
and it proved that there isnt anything to the front 3 plugs....
any ideas on what it could be?
thanks in advance
https://www.sau.com.au/forums/topic/235691-help-needed/
seems you have checked over the spark side of things. now try the fuel?
chesk or swap over the injectors. check all the wiring surounding the injectors for broken or dirty plugs and wires.
are you using the old origional loom?
just a few starters.
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4127638
i was using the original coil pack loom, have replaced it now. am still using original main loom.
i havent swapped the injectors over but there is fuel on the plugs when i check them
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4128727
Have you checked the earths for the coils???
Also check continuity within the loom as i've had that trouble before.
yeh, checked the continuity today, also just brought my meter home from work and tested
the plugs running and there is voltage to the plug....
its really confusing me
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4129010
if you have checked every coil out and you have put a new loom and plugs in than im pretty sure spark is covered. id still be looking for injection pulse to all the injectors or even be swapping the injectors as they may be shagged.
the reason i mentioned them as the front 3 and back 3 injectors are wired kind of seperate so it stands out to me if you are having trouble with 3 of them. they all share a common ignition feed which is 12v on a white with black trace wire. the loom has this main wire comming through to the front 3 injectors where it splices off into 4. 3 wires to the front injectors and 1 wire to a plug at the front of the engine that then turns pack on its self and splices into 3 agin to the rear 3 injectors. all the injectors are then earthed through the ecu individualy and are white wires with coloured traces.
also have you tried a different ignition modual as i have have them fail on 3 cylenders only before. so maybe the front 3 coil packs arent even being swithched.
to check that they are all being switched. Use a test light not a multimetre. Unplug all the coils. check they all have ignition power to them. Put one end of test light on battery earth and the other in the coil pack plug. (should be the red wire that you have ignition on)
check they all have an earth. Put one end of the test light to battery positive and probe each coil plug. (should be the black wire)
then leaving the test light on battery positive and put the other end in the pin in the coil pack plug left. (should be white wire) now get a friend to crank over the car and the test light should flicker on and off. do it to each coil pack plug and you will then know that all the right spark stuff is happening.
then look at the fuel.
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4129354
Got the 32 running today,
after the loom was fixed i
got it hooked up to diagnostics and everything is working fine, except the O2 sensor is stuffed.
replaced the plugs because of them fouling from running like crap but still has a slight niggle.
i dont believe the o2 sensor i the issue,
any recommendations now?
Edited by jangles
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4156335
so your fault was in the wiring? had it been pinched during engine swaps?
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4156956
only the coil loom, one of the wires had an itermittent fault, only firing some times.
reconnected the problem wire and it all worked fine.
by worked fine, i mean everything is getting told to do the right thing
Edited by jangles
https://www.sau.com.au/forums/topic/235691-help-needed/#findComment-4158482
    • Lol a few are like that with no intention of being reborn unfortunately.
    • Done, I'll do mine soon too - whenver I take out the car next. I can cheat and make it quieter by turning off VCT at idle too - but I lose the braps
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
