Item:
RB20/25DET High-mount SteamPipe manifold
Brand Spankers
Price:
$850
To Fit: (What car)
RB20 and RB25
Adelaide, SA
Contact:
See below
Comments:
Welcome all,
Rex has for sale His Prototype high-mount manifold to suit RB20 and RB25. At the moment it's un-flanged, all you have to do is let Him know which flange you're after (T25/T3/T4) and it will be done before it leaves, likewise, if required it can also have the stub outlet for an external gate fitted.
Its brand new and unused. Constructed from High-grade steampipe using a 6 into 1 collector and as near as possible equal length, equal restriction runners then flared and matched to the shapes of the ports. Finish is 1500F silica manifold coating.
Its yours for $850 (fair bit cheaper than the production versions will be)
Located in SA, But can freight around Oz for extra $20
Any questions or queries don't hesitate to ask.
Contact details:
PM or Post here
eMail: two_fat_ladies@hotmail.com
Ph: 0404 027 105
Cheers,
Rex_Kelway
hey buddy
i like the way this looks, can you tell me the dimension of the runners (internal diameter) and also the thickness of the steampipe. looks like a lot of work went into this, when do u expect the production versions to be on the shelves???
thanks
Slav
Hi Slav,
The runners have an ID of 35mm and 4mm wall thickness. There are two more designs He'd like to try but Rex is hoping to have a few different types ready to go in a few weeks.
Thanks for your interest!
Rex
hey buddy
thanks
Slav
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
