Item:
RB20/25DET High-mount SteamPipe manifold
Brand Spankers
Price:
$850
To Fit: (What car)
RB20 and RB25
Adelaide, SA
Contact:
See below
Comments:
Welcome all,
Rex has for sale His Prototype high-mount manifold to suit RB20 and RB25. At the moment it's un-flanged, all you have to do is let Him know which flange you're after (T25/T3/T4) and it will be done before it leaves, likewise, if required it can also have the stub outlet for an external gate fitted.
Its brand new and unused. Constructed from High-grade steampipe using a 6 into 1 collector and as near as possible equal length, equal restriction runners then flared and matched to the shapes of the ports. Finish is 1500F silica manifold coating.
Its yours for $850 (fair bit cheaper than the production versions will be)
Located in SA, But can freight around Oz for extra $20
Any questions or queries don't hesitate to ask.
Contact details:
PM or Post here
eMail: [email protected]
Ph: 0404 027 105
Cheers,
Rex_Kelway
hey buddy
i like the way this looks, can you tell me the dimension of the runners (internal diameter) and also the thickness of the steampipe. looks like a lot of work went into this, when do u expect the production versions to be on the shelves???
thanks
Slav
Hi Slav,
The runners have an ID of 35mm and 4mm wall thickness. There are two more designs He'd like to try but Rex is hoping to have a few different types ready to go in a few weeks.
Thanks for your interest!
Rex
hey buddy
thanks
Slav
    • You're now in the unrestricted member group so upload away!
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
