  • Replies 73
Hi guys, comparing maximum power at one single rpm point is a waste of time. Tell me the average power over the useable rpm range, now that's something meaningful.
Let's compare this R33 GTST..................
At 7,000 rpm it has 310 rwkw
At 6,000 rpm it has 250 rwkw
At 5,000 rpm it has 195 rwkw
At 4,000 rpm it has 93 rwkw
That's an average of 212 rwkw.
With this R32 GTST..........
At 7,000 rpm it has 280 rwkw
At 5,000 rpm it has 200 rwkw
At 4,000 rpm it has 160 rwkw
That's an average of 223 rwkw.
Ignore the weight difference for a moment, which car is going to be faster? The R32 gives away 30 rwkw (11%) max power but I know it's faster (times prove it) and that's because it's average power is higher.
Hope that adds to the discusion
Sydneykid, I totally agree with what your saying, maximum power is irrelevant, hence the reason I get mine tuned for a nice fat power curve and not top-end power. We reduced the top-end power in mine and gained substantially in the mid-range, and that's the type of car I'd much rather drive:D
Originally posted by RNS11Z
Well considering i dont have cams and cam gears, once i get the bigger injectors and bigger fuel pump 440rwhp will be easyly made. The reason why i had to use such high boost to get the power levels its at now is because of my fuel problem. If i were a mechanic.. hey id solve the problem myself and tell you the reason why its not making so much power.. but im not so thats just the way the cookies crumbles.
RNS11Z,
the above doesn't make sense to me in that u had to run more boost b/c of your fuel problem.
i hope your tuner didn't tune your engine by retarding the ignition timing and winding the boost up as to get power without detonation.
If so, you are definitely not allowing the engine to run efficiently and make the power it should on lower boost, so i'd look at getting the engine tuned again with more timing and lower boost as to suit the amount of fuel that your injectors/pump will flow.
For those who are curious, I just found out that the injectors in my car, which i was told and believed were to be 550cc, are actually standard. Goes to show how much you can trust a reputable builder hey!!!
650cc injectors will be installed tomorrow. Will keep you posted with dyno figures.
Cheers
Harun
Cheers
Harun
u cant be serious, 6 x 370cc injectors and 280rwkw dont add up.
u r kidding yourself if you think they are the stock ones.
Just a question why are you guys making well over 300rwhp and only doing mid 13 sec 1/4's? Shouldn't you be getting mid 12's with that much power.
"13.5@104mph, 368rwhp More than Troy "
104 is a very low mph for 368 rwhp.... whats going on here? Dynos can lie, but the track doesn't.
Driver, traction....etc....see some got got mid 12 and high 11..see the sticked post....
Hi RNS11Z, if you car is making a genuine 290 rwkw on standard injectors then you better call the the Pope 'cause it's a miracle. Either that or the fuel pressure is way over the top.
Is it possible that you have a set of hi flowed standard injectors? They look the same and most people don't remove the part numbers when they hi flow them, which is very dangerous. I have seen the result when someone with a set of hi flowed injectors replaces one with one of the same part number (not hi flowed). Very large melted lump that sorta looks like a piston.
Hi sidewaymambo, weight is important too and tyres are the most important, not to mention driver skill. Comparing 1/4 times to judge a cars horsepower is almost as useless as comparing different dynos.
Fun thread this one
Well i was very shocked to find out it was standard. We did back to back testing with another set of standard GTST injectors from a vehicle which was producing 340rwhp and they flowed exactly the same. This guy is also on the forums (the person who i was going to sell my injectors too), he too can vouch for em.
I will post a copy of dyno figures once i get the new injectors in the car and tuned which will be very shortly.
1/4 mile times, well i will be out racing at jamboree so, we'll see how good i can drive and how good my tyres are.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
