Hey,
Interested in floor mat set and ECUs if the sale doesnt go ahead. Any chance of a getting pictures of the mats?
Also if postage to Canberra will be a problem dont worry about the mats.
Thanks!
  • Replies 52
The guy who wanted the 2 ecu's only wants one now.
I'll get some pics up tomorrow of the mats. Postage might be expensive as they are large and quite heavy for what they are.
Hey Gareth any luck on postage costs to Perth for those front driveshafts (axles) i wanted? I got money ready to go, just PM me the details of exact amount and bank info :)
Edited by unique1
I take my motorbike to work all the time and I don't have scales at home. It'll have to be the w/e before I can get a price as I don't have that much time during the day.
No worries, i still want them so let me know when u find out. I know they weigh 6kg each as i have 2 of em sitting right here next to me and i just weighed them. Thats including the big nut, washer, etc on the end which i also need so i can bolt them onto the hub.
cheers mate
I need to reassemble the gauges as one globe was broken and I haven't had a chance to buy one yet. They are very good and have all wiring and sensor. Also have max warning and memory.
I have both of the sway bars available.
Bump.
Also could people stop sending pm's about what is already sold. Have a read though the post first. If I could edit the first post I would but I can't.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
