Make:
Nissan
Model:
Skyline GTR V-SPEC
Milage:
6x,000 km
Transmission:
5MT
Colour:
Dark grey pearl
South eastern suburbs, Melbourne
Complied?
Yes
RWC supplied?
No
Currently registered?
Yes, 11 months rego
Price:
$25,000 FIRM
Swaps for EVO, STI, Supra - PM all offers
Contact:
PM
Call/SMS 0416 623 381
Comments / Modifications:
Genuine V-SPEC with the A-LSD cluster, upgraded ALTESSA and suspension
Always serviced with the best MOTUL oils, gear and engine
Engine never misses a beat, oil pressure gauge almost reads '8' on start up and at cruising sits around the '4' mark which indicates the motor is more than healthy
Gearbox shifts smooth but occasionally crunches into 4th gear as the synchro's are worn, common problem with the GTR gearboxes but other than that its perfect. Shifts smooth every time, clutch engages like new and is perfect for street/track use
$2,xxx worth of receipts from CHASER Motorsports which shows service and maintenance history from early 2008. $1,xxx worth of receipts from CENTRELINE suspension when new bushes were installed and a wheel alignment was completed
Had the car retuned a few weeks back, have receipts to show work completed and also dyno graph to show tune/power figure. The car made 230kw at the wheels on 13psi with a very leaky and shit flowing exhaust, since then I have changed the whole exhaust with new XS power front pipes which got from a 2.5" inlet to a 3" outlet, 3" decat pipe, as well as a new 3" cat back exhaust which has a big resonator to keep it quiet. This exhaust flows 110% better than the last and I have no doubt it will make more power, with a set of cam gears and 14psi the car will easily see 250kw at the wheels
Wheels I put on last weekend, brand new WORK Emotion XD9 in white, 18 x 10 + 18 all around with new TOYO tyres. I have had these on for less than a week along with the front pipes, cat back and decat pipe so they have all done less than 500km
Exterior is in very good condition, paint is great and has come up awesome with a full detail
Engine:
Custom intake piping
TRUST pod filters
XS Power front pipes - New
JJR Type 2 decat pipe - New
TRUST copy 3" stainless cat back - New
Custom water/oil catch tank
SPLITFIRE coil packs
Apexi Power FC - Tuned to 230kw on 13psi (comes with dyno graphs and receipts for tune)
Will come with standard air box and snorkel
Interior & Sound:
New interior floor carpet
Seats, trims and dash are in awesome condition
Near new R33 GTR S3 V-SPEC cluster with super bright LED lights
Super bright LED lights in DIN gauge
Drivers and passenger airbag
PIONEER DEH6050UB head unit
Drive line:
WORK Emotion XD9 in white 18 x 10 + 18 - New
TOYO tyres - New
Slotted front rotors
New lock nuts - Black
XTREME HD clutch
Lightened flywheel
SUPERPRO adjustable caster kit
SUPERPRO adjustable camber kit
Images:
Genuine interest only, no time wasters or offers under 25k because I will not respond
Thanks
https://www.sau.com.au/forums/topic/235746-r33-gtr-v-spec/
Driven this car before, nice exhaust tone, nice rare colour.
However, it's funny, i sold the Greddy Turbo timer to the previous owner i even helped him to install it, are you sure you put it in? I wanted to purchase this vehicle but back then the car had a little 'misfortune'. Is that the new coat of paint resprayed?
Let me know the best price.
Cheers
Edited by BL01
https://www.sau.com.au/forums/topic/235746-r33-gtr-v-spec/#findComment-4132595
hey abu... i know your two bros from pem.... i was a border too.. i cant quite afford 25 though.... gl with sale..... i am up in qld at the moment.. i saw your youngest bro at the pem soccer pub the other week and chatted about a few of my ideas. currently i am looking for a 32 gtr with rwd switch for approx 15g worked.
regards... chris
https://www.sau.com.au/forums/topic/235746-r33-gtr-v-spec/#findComment-4140647
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
