A couple of weeks ago I was in a cab on my way to Melb airport when the driver pointed out a new speed camera.
Rather than the usual camera in a car on the roadside, this one was a radar/speed detector & camera on a small tripod about 2-3 feet high and a silver metal box about .5m squared all sitting on the kerbside, with seemingly noone else around.
I saw another on High St Glen Iris yesterday lunchtime, not far from Malvern Rd intersection.
One each side.
I think I may have been clocked doing 65 in a 60 zone as I was a bit slow in noticing it.
These are going to be huge cash cows for the greedy Vic govt as they are no where near as obvious as the usual cars with tinted windows.
I spoke to a courier yesterday arvo, as they are always on the road. He said his brother-in-law was clocked speeding by one of these, but was not fined as (supposedly) they are still in the testing phase. I'll get back to you on that, pending my letterbox drops. :D
Anyway, here's a pic (taken from a crappy Nokia phone) so you can get to know your enemy. :(
Edited by Mean_R34
https://www.sau.com.au/forums/topic/235764-new-speed-cameras-lurking-in-melb/
  • Replies 43
Posted Images
Surely these are too easy to take care of with a baseball bat? Or even just pushing them over?
there would be some1 lurking around nearby looking after it ... its a potential cash cow 4 the government... they would definately look after them
i work at a landfill i might talk to some truckies .... get the to use there bin grabber early one morning .. and just pluck it up from the side of the road .. and keep going ... be perfect and no one would know .. in about 4hours after that we would have burried it in like 85tones of more rubbish and building scrap
best way to find out ... park next to it for about 10mins .. turn car off ... im sure if they think something is up they will come over to investigate .. your not doing anything wrong .. be on your phone to make it look legit tho
Who cares if it is 'legit'
I've parked infront of the parked car speed camera's before (was near where i was staying).
Stuff em.
The dude came out and said he was trying to operate a speed detection device and i was in his camera's line which affected it.
I said, ye i know, and asked if i could move it, i said nup. Went inside :)
He also said it took a little while to setup etc
So must have been a pain in the ass :)
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
