There a ways with dealing with the old school speed cameras too, just a story i thought i would share. It occured in brisbane on a strech of high way that drops from 90 to 60 and often has speed traps set up there. I saw in a small story in the newspaper that some legend had snuck up to the car the camera was housed in, and stole its number plates. He then proceeded to attach them to his car and continuosly speed past the trap. Police couldnt do shit about it, they couldnt find out who it was. How the paper found out about it im not sure, but probably why it was such a small story.
  • Replies 43
Posted Images
i think they would 150% have tacking GPS in them. the box that houses the gutz looks fairly tough ive seen this being trial'd on williams road. they are very small and short devices and i think it might eliminate the need to have a car wich would cost quite a bit. the only thing that i was wondering, is the battery housed in that little box? so all it would take is the wires to be cut and you have a perfect tri-pod that does nothing?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
