Hey guys, bout time I got rid of some stuff thats taking up place in my garage...
HKS Mushroom Pod Filter - You all know what these are so don't need to explain much - $50 ono
2 x Single 2.5" into twin 3.5" upswept exhaust tips - few minor scratches all on the under side, had these on for four weeks then had to change due to body kit. They look very tough - $30 Each or the pair for $50
Polished stainless muffler Single 2.5" IN twin 2.5" OUT - came of a mates car has a very nice note to it - $50
R33 skyline DeCat pipe with Sensor fitting - Had this made up for my skyline no longer required, it was made for an R33 but might suit other cars not sure - $50 ono
Trust Muffler off my R33 3" in with 4.5" Tip - This is a genuine Trust muffler and has an awsome note to it plus has the larger body (not a cannon) which makes the car fairly quite at low revs but when you get into it sounds awsome - $95 ono
Genie Cannon 3" in with 5" tip - This cannon is massive and sounds insane plus looks awsome had it on my R33 and definetly stood out - $95 ono
Pair of R33 tail lights - Good condition don't really need to explain much - $40 each or $70 for the pair
Set of Series 1 R33 RB25DET Coil packs - Working fine when removed from car, removed due to rebuilding whole motor and putting external coils in. - $30 each or $150 for the whole set
RB25DET Tommy Kaira Engine Cover - came from my motor but due to going external coils could no longer use looks awsome and really sets of the engine bay. It's fully cast - $200 ono
R33 Series 1 Nismo Wing - painted marron and no damage, It the one thats a bit higher than the standard one and sticks out over the back of the car - $100
Sony Rear Projection TV 68cm not widescreen - $50
Benq 17" LCD monitor - $50
Geforce Graphics car for computers - Great upgrade to a standard system - $30
I'll get more pics if anyone wants something in particular
Contact me via PM, need to get some funds for this weekend so if theres somethin you want give me an offer and i'll consider it
https://www.sau.com.au/forums/topic/235769-garage-cleanout/
  • 1 year later...
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
