Garage Cleanout
Hey guys, bout time I got rid of some stuff thats taking up place in my garage...
HKS Mushroom Pod Filter - You all know what these are so don't need to explain much - $50 ono
2 x Single 2.5" into twin 3.5" upswept exhaust tips - few minor scratches all on the under side, had these on for four weeks then had to change due to body kit. They look very tough - $30 Each or the pair for $50
Polished stainless muffler Single 2.5" IN twin 2.5" OUT - came of a mates car has a very nice note to it - $50
R33 skyline DeCat pipe with Sensor fitting - Had this made up for my skyline no longer required, it was made for an R33 but might suit other cars not sure - $50 ono
Trust Muffler off my R33 3" in with 4.5" Tip - This is a genuine Trust muffler and has an awsome note to it plus has the larger body (not a cannon) which makes the car fairly quite at low revs but when you get into it sounds awsome - $95 ono
Genie Cannon 3" in with 5" tip - This cannon is massive and sounds insane plus looks awsome had it on my R33 and definetly stood out - $95 ono
Pair of R33 tail lights - Good condition don't really need to explain much - $40 each or $70 for the pair
Set of Series 1 R33 RB25DET Coil packs - Working fine when removed from car, removed due to rebuilding whole motor and putting external coils in. - $30 each or $150 for the whole set
RB25DET Tommy Kaira Engine Cover - came from my motor but due to going external coils could no longer use looks awsome and really sets of the engine bay. It's fully cast - $200 ono
R33 Series 1 Nismo Wing - painted marron and no damage, It the one thats a bit higher than the standard one and sticks out over the back of the car - $100
Sony Rear Projection TV 68cm not widescreen - $50
Benq 17" LCD monitor - $50
Geforce Graphics car for computers - Great upgrade to a standard system - $30
I'll get more pics if anyone wants something in particular
Contact me via PM, need to get some funds for this weekend so if theres somethin you want give me an offer and i'll consider it
  • 1 year later...
 Share
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
    • Water's still going to come in without the side hatch being refitted.
    • Front end back on! Look at that beautiful sub 🥰
    • GT-R owners love drag racing, here's a S58 stock motor, stock turbos doing a 8.9s   https://www.instagram.com/p/DBq0s10pkx5/
