hey guys last night i became the proud owner of a '97 rs4 and all was going well, took it for a boost up the express way absolutley loving the power delivery and ride comfort, tore around a couple of back streets good stuff.
anyway I was almost home down a back street when upon accelerating hard and hitting 60kph my speedo, tacho and fuel gauge cut out and just went to zero as if the car was off, now the strange thing is the car was working fine still speed up and slowed down with no issues.
got home turned the car off left it for a minute and then turned it back on but the gauges still didnt move. went inside and called the previous owner and he said he had never encountered this issue.
went back outside turned the car on and then all the gauges were working took the car round the block and everything was peachy..
anyone encounted this issue before? what do you think the problem might be?
I find it a bit suss that the car is 11 years old with no issues and i have it for half an hour and something goes wrong.
any help would be greatly appreciated
https://www.sau.com.au/forums/topic/235775-weird-issue/
like mike said, undo all connections off back of cluster and re-attach them, also could be a bad connection in the fuse box, pull all the fuses out and push them back in. Spray all of the connections with a contact cleaner if you want to be fussy.
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4128437
Did your warning lights come on? Did anything else happen or just the gauges died.
if your warning lights started flashing also, then I'd be saying your getting low voltage problems. Check your battery condition.. you'd be surprised how many issues stem from a bad battery!
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4131569
sorry its a bit off topic, but just reading about how to get the steering column shroud off, i was wondering if anyone has installed a turbo timer them selves.... I'm just not sure whether to try it myself or just get an auto leccy to do it...
Cheers, Bradd
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4132518
Cheers, Bradd
Mine was already in the car but if you are getting a brand new one it should come with wiring instructions and you can have alook and see if it means anything to you and if not a sparky should be able to do it in 30 mins (or phone around a couple and ask for a price).
https://www.sau.com.au/forums/topic/235775-weird-issue/#findComment-4132583
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
