Has anyone in Sydney had his rocker covers painted?
Got some pics? Would you recommend them to me, and if so, what are their contact details?
North Shore or Eastern Suburbs Sydney preferred.
Thanks in advance.
https://www.sau.com.au/forums/topic/23578-painting-rocker-covers/
I've been wanting to do this as well while my motor is out.
Do you want it gloss maroon red like the R34 GT-R? That's something I would like.
Just the rocker covers, maybe the cam gear covers too. That plus a fancy oil cap would make it nice.
VHT engine enamel and some polish might do it.
T.
That's right, I want mine done in R34 RB26 Red, so a can of spray paint will NOT suffice.
I want it done properly by a professional panel beater/painter who has done it before and knows what their doing :)
Hmm...
This will take a while and be reasonable expensive. So what I say?
It's more like how long your car's gonna be off the road.
I would think this requires a prime, several coats, clear coat and maybe some bakes in an oven to 150 degrees (yeah I've been looking into this at work).
I'll ask a painter about this.
T.
Expensive? I can't see it being more than a couple of hundred bucks, but yeah, more expensive than VHT :)
As for time off the road, if they don't stuff around it shouldn't take more than 2 days, 3 at the most...
It is not expensive..
Andrew, a friend at work has recently had some parts of his VW sand blasted and powdercoated. Whilst the job he had wont be the same as what you need, it was not costly. The powdercoating and sandblasting of each wheel was 40 dollars.
The place he went to is out west, (not convinent for NS folk) but I shall get the name none the less.
Originally posted by T0nyGTSt
I'm on this one right now...
The deal is maroon red like the r34.
Painted rockers x 2, cam cover + plastic centre piece with the Nissan legends masked off.
T.
Thanks for the help guys...
It has to be EXACTLY R34 RB26 red... I am trying to get the paint code (hopefully tomorrow), either that, or I can borrow someone's R34 spark plug cover to get the panel beaters to paint match...
It can't be just *any* maroon red :)
Actually, I remembered that Peter (ADVAN built Maroon R33 - "DA MAN") had painted RB26 rocker covers, and I found this photo of his engine that I took...
http://photos.fortheboyz.com/0211sasfinal/..._IMG.jpg&page=1
I'll give Peter Hopkins @ ADVAN a call and see if he knows where it was done... Looks like a top notch job!
I like mine airbrushed with the purple teletubbie please!
Andrew, Nungen has a second hand rocker cover for R32/33 that's like the red on the R34. Only it's got the R32/33 badge not the R34.
http://www.nengun.siteblast.com/gallery.as...ge=2&shopperid=
I am a friend of Peter (DA MAN), and he referred me to Prestige Motor Sport in Rydalmere, where he had it done.
I have some pictures of his engine bay, but don't feel comfortable posting without his permission (the above pic does it no justice)
Ask for Axle, he is a really cool guy.
Mate of mine has a compressor, and a spray gun, and does his own work.
He's done his own rocker cover, and fuel rail on his GTiR and the rocker cover of a CA18DET...this is just what i remember recently. His pulsar is Top Secret Gold, so's the cover. The CA was done in white with blue pearl, but he neglected to clean the gun properly...so he got some gold in there also. Look gorgeous...like the Pearl white the soarers come in...really nice.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
