I had an R33 GTS-T before hand which was 175rwkw, this one is pretty stock apart from boost controller and exhaust.
Will i notice much of a difference?
Edited by BillyMako
https://www.sau.com.au/forums/topic/235783-getting-r32-gtr/#findComment-4128688
should i get this instead?
http://carsales.com.au/used-cars/private/N...mode%20matchany
The following modifications are:
* APEXI blow off valve x 2
* APEXI dump pipes x 2
* APEXI Titanium exhaust ($5000)
* After market intercooler
* Tinted windows
* Custom GTR mats
* PSR waste gates x 2
* N1 turbos x2
* Pioneer stereo
* ENKEI racing 17'' mags/tyres 17/255/40 ($5000)
* APEXI pod filters x2 + piping
* Gredy adjustable suspension
* After marketPlenimum chamber ($3500)
Power reaches 322kw at all 4 wheels, however there is a fuel leak in the injectors so it wont reach that high.
Edited by BillyMako
https://www.sau.com.au/forums/topic/235783-getting-r32-gtr/#findComment-4128857
Yeah I would pass on this 32 as well. Sand blasted plenum can mean that car has had a hard life or driven at full potential for a long period like track work.
Also you have to be sure that floor,inner guards are not rusted.
However if you can not get more detail info/photos then it has to be very cheap if you really like it.
When I got mine looked very clean but later I've had to invest about 6K to remove all the rust from underbody it was a total resto whole interior removed and all.
Just be carefull.
Good Luck mate :D
Dave
https://www.sau.com.au/forums/topic/235783-getting-r32-gtr/#findComment-4136142
Which colour rims do you guys would suit it best?
So far im going with bronze.
On the white GTR I would go with black/gunmetal rays g-lights 57 pro.That would look insane and very mean.
https://www.sau.com.au/forums/topic/235783-getting-r32-gtr/#findComment-4136151
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
