Hi all.
I'm new to this forum. I have just bought an R32 with an RB25DET NEO conversion. It's in a zillion pieces and I'm going to repaint it, engineer it and use it as a weekend warrior. I have a couple of questions though.
When the motor is running, oil pressure is very high. The motor has an RB25 oil pressure sensor but an R32 oil pressure gauge. Does the RB25 and the RB20 send the same voltage signal to the oil pressure gauge, or is the high oil pressure an indicator of a blocked oil return etc (I've only run the motor for about 10 minutes so far).
Secondly, do front mount intercoolers need to be engineered? If so I'll put it in before taking it to get engineered. If not, I'll do it after.
Thirdly, can anyone recommend a good engineer in the Adelaide Hills area?
Cheers!
Sparky
https://www.sau.com.au/forums/topic/235794-noob-car-plans-and-questions/
I dont think you will have to get the engine engineered, just upgrade to 34 GT-T rotors and calipers and you should be fine with regency. FMIC's do not need to be engineered, however they will only be legal if there is no cutting/modification to the reo, no cutting/modification to the chassis and it is bolted on correctly so that it deosn't move around (including the piping). AFAIK anyway...
Definately a sweet little project you've got yourself, good luck!!
32 with rb25 neo! ::::::::::::::::::::::::::::::P
nice car by the sounds mate! hope it gets out and works alright for ya! goodluck! try the recommended workshops thrread on sau, and nissansilvia.com for some ideas for engineers
if you can take the car for a quick drive and get the car at full temp see what happens to the temp. once my car is first started the oil pressure is abit high but drops after the car gets to full temp.
front mounts are not illegal if you havent cut through the chassis or damaged ther reo as damo_34 has said and mounted correctly.
apply at regency for an engine swap form thing and send it through to them and see what they say. if you have the correct rated breaks to the engine you could get away with it but if not youll need to get the car engineered. if they say this, ask them for which engineer to use, i know on their site somewhere they have a huge list of them to pick from
here you go mate, this could be usefull to you. scroll down to about the 6th page and work your way thorugh it :)
http://www.transport.sa.gov.au/pdfs/person..._bulletin_3.pdf
and heres that list of engineers that i was talking about. could be worth talking to them before regency i recomend Rory thompson!
http://www.transport.sa.gov.au/pdfs/person...d_engineers.pdf
happy reading :)
kye
Cheers for all the help peeps!
ovrtym33, I'll get in touch with you if Regency say 33 brakes are enough. Do you have the calipers too or just the rotors?
ImportS13, cheers for the links. I dropped into JAZMAC performance in Mt Barker the other day, he also recommended Rory.
All others, cheers for the positive comments. I'm looking forward to getting it on the road.
RE oil pressure, it sits on 8 when idling and climbs above the gauge when revved hard, which I think is way too high. What grade oil should be used in them? As it's possibly too viscous and not flowing well enough. I need to do a full fluid change.
7.5w40 or 10w40 is what most people use. 80psi is normal on my aftermarket gauge for idle when the car has just been cranked. once the oil has warmed up it sits on 30 psi. If I drive the car after its just been started, pressure goes past 80, but never 100psi (which is the max of my gauge). Most times it sits on 40/50 psi while driving after engine is hot, with an idle of 25-30psi. If you get below 20psi, be concerned.
-D
Edited by Dohmar
Well I did an oil/filter change using genuine Nissan parts and it still registered very high. So I bought an oil pressure tester and an engine manual. I connected it up to the block and warmed up the motor. The pressures just over what the book says it should be on, so I'm happy with that. The problem is with the oil pressure gauge. I could mount an aftermarket one but I'd like all factory guages to display the correct figure.
There's obviously a voltage difference between the RB20 and RB25 oil pressure sensors, however they're listed in the parts catalogue as using the same sensor!!?? Any thoughts? Can I get the stock 32 gauge recalibrated?
I know one member here had a HUGE issue with engineering her NEO engined R32 - particularly with the brakes.
Apparently the RTA were real idiots with regards to it requiring a particular rotor thickness, and thicker ones wouldn't pass!
It can and has been done however.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
    • nice work, welcome to the world of CAD! fabricating accurately in 3 dimensional space is beyond me....I almost always end up making something more than once...sorry I mean I extensively use prototyping
