Wrecking R33 Turbo Auto Coupe
My point was that it was not a modification/transplant that someone had done. That it was factory. Soz. Should have made that clear.
Absolutely they are. Smaller, modern, efficient > clunky old 80s shit.
I'm looking at it now. The price dosent seem that bad.. a new R32 GTR AC compressor is $500-600 here in the states. It looks like they are using a different compressor though from a Toyota Echo.
There's a few other differences between S1/S2 that you will have to deal with, including either using an S2 coil pack harness or modifying your S1 coil harness to bypass the igniter. So short answer to your question, just buy an S1 ecu. They're probably giving the things away now. Long answer to your question, yes it can probably be done, but refer back to short answer for best option. I would never use an RB25 ECU to run an RB20. Cheers,
