hey guys
hopefully someone can help me out
was driving home just now and it was raining
put my foot down a bit and hit the limiter in second and when i changed to third and tried to keep driving at a normal pace
i hear a high pitched whistling noise and i cant make the car rev over 2000 rpm in any gear
i was thinking that i had blown off a pipe somewhere but when i got it home into the shed there are no pipes coming off
and when i rev it i can hear the high pitched noise coming from the pod filter
but on idle the car sounds normal, no metal sounds to indicate a turbine wheel etc
and theres no black smoke when i rev it
any one have an idea?
cheers
https://www.sau.com.au/forums/topic/235847-blown-turbo/
all the cooler pipes are on and theres no leaks
sadly it is the turbo :laugh:
had a look today
the intake wheels bearing is stuffed
the turbo still spins but doesnt make much pressure
i took the cooler pipe off just before the cross over pipe and can feel it blowing air through and can hear the sound from the turbo echoing up the pipe
the car will rev if its in neutral but wont move properly when under load
looks like its new turbo time
anyone have a turbo i can buy?
need a direct swap for the stock rb25 turbo
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4130337
I've got a stock rb25 turbo off a series 2 33 I've just taken off. Assume it's in good condition, ran fine while it was on but i've got no idea how to check. Let me know if you're interested.
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4131859
hey there, mate i think i got the same problem, ive just change my spark plugs to bcp6res ones and now when i put my foot down slowly... i can hear a wierd strange high pitched whissle, could it also be the blow of valve?
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4132186
my r34 has the same high pitched sound at the moment sounds like it from the vicinity of the turbo mine still makes boost thou 10psi but it screaming, screech sound is terrible......i thought it mite be a boost leak but i aint found it......
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4133036
i have been told it might be an exhaust manifold leak may need a gasket?? hopefully turbo not on its way like the thread starters car........ i dont really have the patience to pull the thing apart.... time to take it to a workshop.....the joy of turbo cars ! hehe
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4133136
Damn mine blew about 2 weeks ago but it's all up and running again. They must all be throwing the towel in these days.
It's not that hard to change the turbo if you get another standard one. Could do it in an afternoon. With that said a workshop probably wouldn't charge that much if it only took an afternoon so.. Just do it yaself and learn lots along the way;)
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4135301
Grab a hold of the shaft and try and pull and push it and see if there's any movement that way or side to side or anything. Also check how freely it spins and if there's any bearing noises or vibrations as it turns:)
Edited by JET-25L
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4135308
Its probably this crap fuel they are all slowly fazing in without us knowing. All upping the ethanol levels or something...
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4135363
wtf does that have to do with turbos dying?
My 25 turbo is still going strong, it spent about a year at 12psi on an RB20 and nearly another year on an RB30!
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4135417
Just something on the bcp6es plugs... i had the iridium version of these in my car originally... then changed to the $4 BKR6E plugs with a smaller gap and it ran so much better. I always use these plugs now and i recommend these to anyone that brings an rb25 into my work.
rgr34 a whistling noise is usually a vacuum leak... doesn't necessarily affect idle too much but when you get up it it will be easily noticeable. Does it struggle to make that 10psi now? I'd be checking everything carefully and making sure it's all legit.
If you've got a leak between the turbo and manifold you should be able to hear air blowing out of it or heaps louder exhaust noise from the engine bay. Good luck!
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4137248
the noise i have is like a supercharger, a winning noise... its really wierd...
I had a FMIC and EBC installed, and boost upped to only 9 psi. Since then I've had a similar sound, when i hit full boost i can hear a metalic whining sound, similar to a supercharger sound. Not sure if the turbo is bad or if its just the sound resonating through the new cooler.
https://www.sau.com.au/forums/topic/235847-blown-turbo/#findComment-4139110
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
