I think my stagea is down on power. I put it on the dyno and i only got 110kw at all 4's and i think its supposed to be around 130kw and ive also noticed that it doesnt idle smooth sometimes. It feels as though its missing. It has brand new splitfire coilpacks and platinum plugs gapped to 0.8 and its holding boost pressure and drives smooth. Can anyone help?
Can you post up your dyno graph? What is the air/fuel like? If you have spark and compression check out the fule supply (filter, pump, regulator, injectors) - what did the dyno guys have to say? If its totally ummodified 110kw isn't too bad.
what are the mods?
stock stagea only puts out 110kw at the wheels
with cat back 120kw, full exhaust 130kw, bigger fuel pump & safc 140kw, sitc & bigger intercooler 160kw, bigger turbo 180kw, ecu remap 200kw
what are the mods?
stock apart from pod and splitfire coil packs. I wouldnt mind sorting out this miss that its got on idle somtimes. Might try o2 sensor and new injectors cause my afm looks spotless. Can u get the injectors cleaned or checked?
Edited by sturb25
try cheap 0.8mm pre-gapped ngk copper sparkies first. bcpre6
$3 each, they'll go well with the splitfires
110kw is normal for pod filter & splitfires, :O
Ive already put platinums in and they were gapped at 0.8mm. Thanks My mind will rest abit easier now about the power issue. I just need more. going from a vl rb25 with 250kw at the rears to 110 sucks. It been hard!
Is this correct for a Series 2 given approx. 206Kw at flywheel?
Didn't notice it was a neo engine ...that should give about 130AWKW
Haven't seen the air/fuel ratios ...could still be a fuel problem.
yeah its a neo, should it have more than 110awkw? I cant get my dyno sheet at the moment its in storage. Going to try and get it 2day then ill post it up.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
