so dad took my stagea on friday to pick sumthing up... cleaning it thismorning (sat) i discover that 1/3 of the wheel has been gutter rashed the whole way along :'( its a chrome lip so its not going to be easy to fix i dont think. duz any one have any advice on where/were not to go? and about how much its going to set HIM back haha. duz it take long? cheers
pic attached.
https://www.sau.com.au/forums/topic/235870-gutter-rash/
pic attached.
Hey mate,
Adelaide Wheel and Rim. 308-310 south rd richmond. 83526266.
Need to get the rim off the car and the tyre stripped.
Drop it to them, generally a 2 day wait.
Id guestimate about $170
Used them a few times, highly recommend them.
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4130246
pic attached.
That sucks, my girlfriend did mine too, I havent got it fixed yet Ill ask a mate he seems to know somewhere, so he says.
Ill PM you once I have askend him again.
Oz
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4130249
Hey mate,
Thats The Place!!!
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4130251
hey Chef, i sanded the marks outta mine with 80 grit paper, 340 wet, 600 wet, 800 wet, then working my way down to 1200 grit sandpaper and polishing the metal. takes awhile but works. also if u know someone with a lathe, u can machine the marks out
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4130298
Sam that'll work fine for polished alloy (I even have a bench buff for that extra final touch) but won't work with chrome unfortunately.......if it is chrome, it'll just peel.
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4130396
ah good point Sled, i shoulda mentioned that. best to find out weather the rims are polished metal or chrome plate first :nyaanyaa:
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4130590
if adelaide wheel and rim cant fix it for you mate
then i would say try extensive wheel services a go....they are directly opposite adelaide wheel and rim services.
i have dealt with them a couple of times and they are a top bunch over there and know what they are doing
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4132932
+1 for what ben said. Ive been there b4. only charged 80 bucks. all good.
the place accross the road frmo them will charge you more.
Im doing the same thing myself soon. who knows a place that can powder coat wheels nice ? smooth black finish. with gloss ?
I used to powdercoat myself when i worked at ROH. wish I was still there sometimes.
https://www.sau.com.au/forums/topic/235870-gutter-rash/#findComment-4133064
    • I can't help with the clearance question, I've always taken my machine shop's advice on that. It is worth considering that a shop that does that every day for road cars will be looking for as good as they can get off the shelf, not perfect. If you want more careful race style "blueprinting" then you need a race shop to measure/machine the engine. I do have an opinion on line boring the block though....don't do it unless you have to. The crank centre moves higher but the oil pump stays in the same place when you line bore the block.
    • Hey that reminds me, are you changing your forum name to "The Hairdresser" too?
    • There's no figuring out with a Haltech, you literally load up the base map, plug in the vac/boost reference from your manifold to the ECU (or an external MAP) sensor, wire up an IAT and it will run pretty well out of the box. The ignition tables are quite well defined and safe enough for someone to give it a hit (although I don't recommend it if you've got anything besides the stock gear on the motor).
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
