Everything afaik (why im asking) is off the car.. it will go up and go side to side.. doesn't want to budge too much forward thought..
We have an 1 1/2 inch of clearance between motor and housing... trying to loosen the throw-out bearing of the crank :nyaanyaa:
im sure there is something a miss... The car is a 93 GTR with the pull type clutch (sure im missing something here)
So if anyone has some handy tips, please share..
Probably won't be able to check up on this as much over the next few hours but if your feeling generous or on a cap please call ..
0431 520 274 Thomas..
Worth a try :w00t:
OK so We've already made a gap between the motor and the box, and we have read the FAQ about removing the pull type clutch, but because we have already prised the engine apart and removed the slave cylinder, the clutch fork is now solid against the inspection port.
My mate has had a look into the inspection port and couldn't see this pin and clip that everyone is talking about.
Hes a bit of a gun on mitsus but doesnt know GTRs at all so we are having trouble.....
Do we need to put the engine back onto the box and replace the slave and try to disconnect the pin/clip (not that we can see the F#$%in thing) from the clutch fork or is there another way?
Purple monkey dishwasher :nyaanyaa::w00t:
If your reading this Duncan hint hint ;)
Edited by Tomek
mmmmm... So we dropped the motor down aligned it with the housing and pushed and levered it towards the back of the car... Didn't have to have it on all the way, we slowly got enough clearance with persistence and got to the clip...
lol.. sorry couldn't help myself
yeah, you need to remove the pin in the for....
oh f**k it, I think you worked it out.
BTW I can see the problem, there is a person in your engine bay not an engine
Yes as you can see I eliminated the GTR's under-steer flaw with the sacrifice of horse power :thanks:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
