Hi, just purchased a New Autometer Cobalt gauge but no instructions as the previous owner purchased the tach but never installed it and managed to lose the installation instructions in the process.
NOW. Which wire do I clip on the back of the Autometer Tacho for a R33 Skyline ??? Do I clip the brown wire only ?? OR do I clip both the brown AND blue wires ? also, do I hook up the green wire to the tach output on the ECU ?
Any help is appreciated.
https://www.sau.com.au/forums/topic/235940-autometer-tacho-wiring/
http://www.autometer.com/cat_gaugedetail.a...=2580&sid=4
Google is your friend :thanks: Just click on download instructions.
Pretty much only cut the brown wire. According to the instructions the blue wire is used for something, but dont think you will actually need it. so pretty much do:
Green = ECU tacho output
White = Dash Lighting
Red = Connect to ignition with a fuse
Black = ground
And you should be fine :P
