Hi guys, just after some info on short shift kits for the R33....
Just seeing what brands you guys are using your experience with them, Im thinking about getting a C's short shift from Atomicbomberman (30% shorter) over the 10% shorter nismo item... Comments appreciated,
Lepperfish... :burnout:
https://www.sau.com.au/forums/topic/23596-short-shift-kits/
i've got one... not sure what brand but if i have a 25 box, it's VERY short and it's harder on the box i reckon.
You have to be precise with your shifts or they can crunch on not go into gear...
maybe redline oil might fix mine?
but ATM it's rough, but i'm used to it now. Plus my box is well used, that probably doesn't help.
PM dj_lethal... he just got one in his 33. Was around the same tightness as my box, but i think mine it a big tighter
https://www.sau.com.au/forums/topic/23596-short-shift-kits/#findComment-505509
i got a short shifter with the car - never compared it to a non-short shifted one.
I think the throw is not all THAT short actually. I think mine might be a Nismo one if it is only 10% shorter
What other brands of short shifters are available in Japan (so I can narrow down the brands)? The only ones i hear thrown up around here are the C's and the Nismo ones.
https://www.sau.com.au/forums/topic/23596-short-shift-kits/#findComment-505596
I've a C's one in for a long time now....wouldn't be without it .By comparrison the normal shift feels really long and sloppy. Ihave heard that you need to check if you'r getting Nismo.... there is a 10% and a 30%.
https://www.sau.com.au/forums/topic/23596-short-shift-kits/#findComment-505989
i got one with my car and its ALOT shorter than all the other skyline box's ive had a go on so it must be the 30% one. its alot nicer to drive and gives the car a much nicer feel as the gearing is precise and there is no play/sloppyness.
also makes it easier to slam through the gears quickly.
Shaun
https://www.sau.com.au/forums/topic/23596-short-shift-kits/#findComment-507465
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
