Questions On Repairing Some Aesthetic Aspects Of My Car
hi all, i know this isn't directly the place to post this, but being a problem im looking to have repaired, somewhere in say, melbourne wouldn't be my best choice.
I recently purchased an R33 knowing it had some work required to be done to it, but however, i couldn't do it myself so im wondering if anyone can point me in the direction of a place that could help me out.
My problems are the following
Power windows wont operate (passenger side works sometimes) i believe that problem to be in the relay itself, but the drivers side i believe to be burnt out (the auto on button locks down, so i believe the previous owner just gave up on that) wouldn't be such a problem if they weren't down
second problem is that the central locking doesn't work on the drivers side, so i hit the central locking and it opens passenger side, but not drivers side. (this is right from the panel on the door itself, or by manually locking/unlocking) could be a problem with the actuators in the drivers panel.
This is normal...the switch only does the passenger side door.
yeah agree with above :)
normally when you get central locking with your alarm you need buy a seperate relay (about $120ish) to put in to get the drivers side to open perhaps the previous owner skipped that.
Edited by Inline 6
The window relays are a pretty common problem, but actually not too hard to fix (providing you have soldering gear). There is a thread on fixing them in the DIY forum
ok so, the window is a tad more damaged than i initially thought (everything inside the door regarding the window basically needs replacing)
can anyone recommend a decent place to get this done?
other things aren't that big an issue, just need my windows fixed ><
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
