Boost Drop, Stock intercooler or stock Turbo?
Guest Robo's
Seems a few of use are under the debate and testing, that we are experiencing boost drop at full throttle. My example was on my recent dyno tune, that i peeked in mid range in the high 11's and low 12's but as revs increased my boost dropped to a point of 10psi at max revs.
So the question is, the guys with FMIC , EBC, or different turbos are you experiensing the same?
Is it the stock intercooler having inadequate flow?
Or the stock turbo ineffeciencies?
Or maybe the Boost controller?
My stock turbo would give me 12.5psi till about 4500rpm where it dropped suddenly off to 9.5psi. I have the blitz sbc boost controller and we put it down to that or the wastegate actuator. With the TD06 on now boost holds nice and flat with maybe a 0.5psi drop in the high end so it was the wastegate actuator spring. HKS make a wastegate actuator with a stronger spring, but even still at around 12-13psi the stock turbo is really reaching the end of its efficiency range so its gonna start dropping a bit of boost at the top end. I've seen a car with a bleed valve and a powerfc make around 270ish HP @ treads with the stock intercooler, though I didnt see his boost graph.
I have a front mount with a turbosmart bleed valve and standard turbo. My boost drops from about 12psi to 10 psi between 6500rpm - 7000rpm.
Im pretty sure in my case its either the wastegate or bleed valve because everything is relatively efficient ie, new dump pipe/exhaust, HKS filter, PFC.
Hope that helps,
Any tried the 1 bar HKS wastegate actuator to fix this problem? Has it helped?
Standard turbo dropping from 16 psi back to 13 psi.
Have FMIC and PFC so I don't think it's the I/C
Also trying to work out if it's leaky BOV, Boost controller (manual now) or wastegate actuator.
Originally posted by wrxhoon
its normal ,
the turbo is not big enough to hold boost at high revs .
the higher the rpm the more air it has to pump thats way u get a drop in boost , if u can hold max boost at 6000 u r doing well .
Can you explain why then, that my car held 0.85 bar (12.5lbs) all the way to 7200rpm, in fourth gear?
the wastegate acutator is the issue. It isn't the best quality unit in the world.
The HKS actuator will help, isn't really worth it on the stock turbo though. Dropping boost probably saves the factory one from going bang sometimes.
I know when i last ran mine with EBC with stock turbo and intercooler it shot straight to 10psi at about 2600rpm and held flat tapering off maybe 0.5psi all the way til 7 grand.
Now i got front mount....damn i love that thing. boost is super flat.
That may of been mine. Even if not i still qualify as stock turbo cooler bleed valve and Power FC
here is a graph before the PFC was fine tuned
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
