NOTE_I bought this car 21/09/06 1st aus owner had 51,000kms on the clock and always been garaged the images were taken 3wks ago car is a little dirty just needs wash PLS no time wasters will give 100% attention to interested parties
This car is advertised on www.carsales.com.au
Make: Nissan
Model: Skyline R33 GTS-T Series 1 M-SPEC
Milage: 75,434 Changed oil at this reading on sat 13/09/08 previous was 71,300ish about 5 months ago
Transmission: Manual
Colour: Black
Complied? YES
RWC supplied? YES
Currently registered? YES runs out 21/09/08 but for $16,000 will have full yr rego $15,500 no rego
Price: $16,000 as I have spent good money on good parts price is not that neg, if you know what your looking at price is very cheap
Contact: PM
Comments / Modifications:
Volk racing 17" rims pirelli p zero front and unknown 17/255 on rear
bilstein suspension all round
Xtreme Dampened Solid Button (DSB) Motorsport Kit + Flywheel Part number: KNI24501DSBMSCF Clamp load on the cover is 1600kg - a massive 130% upgrade from standard!! xtreme lightweight flywheel (Chrome-Moly 5.5kg) http://www.xtremeclutch.com.au/page.asp?pa...mp;productid=14 this clutch can be rebuilt so no need to ever replace $$$$ save $$$$
Walbro 600hp fuel pump
Alarm worth $1,500 specs on sale
Powerpulse Battery worth $500.00
Exhaust
NARDI wheel & gearshift
There are other bits that I have that may be sold with the car with $$$ most never used with receipts pay less than from the shop
eg: tail lights with garnish
Turbosmart megasonic blow off valve
strut brace front
B pillar brace
Autometer Pro comp silver boost, oil temp and pressure, water temp gauges cups mounts etc
Stereo 6" splits 6" rear 2x12" pioneer subs boxed with 600w amp sony head unit flip down
Images:
Edited by 2SHIFTY
https://www.sau.com.au/forums/topic/236055-r33-gts-t-m_spec-s1/
EDIT
Owner/Driver/Vehicle History: 26 yr old male car never drifted or taken to the track car Enthusiast. Car is very clean minnor wear on the drivers seat (very common), car is always complemented on over the condition of the vehicle, regretful sale due to debts and settleing down with girlfriend pressure to move out from the olds. Car will not disappoint. very reliable 1 break down due to fuel pump always serviced and maintained.
Make: Nissan
Colour: Black
Complied? YES
RWC supplied? YES
Contact: PM
Exhaust
Stereo: Sony head unit with Clarion 6" splits 6" rear
strut brace front
B pillar brace
Images: See original post
Edited by 2SHIFTY
  • 4 weeks later...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
