Nick378 Posted September 14, 2008 Share Posted September 14, 2008 Hi there, i just installed a new fmic with the piping kit and now, i wonder where to fit my boost control valve vacuum hose. The kit had a "T" fitting but no instruction that tell where to install it. So i figured out the only place was on the blow off valve. I wasn't sure about this but it seem to run very well. Still, is it safe and is it the right place to fit the vacuum hose? See my boost controller valve to the right? the pink hose go to the blow off valve to the left. And that's how i connected it. So.. is it ok or i should weld a nozzle on the piping to keep it like the oem one? Thanks! Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/ Share on other sites More sharing options...
Nick378 Posted September 15, 2008 Author Share Posted September 15, 2008 anyone? Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4134627 Share on other sites More sharing options...
Dragonforce Posted September 15, 2008 Share Posted September 15, 2008 sorry man... but why pink hose? Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4134771 Share on other sites More sharing options...
Redsuns88 Posted September 15, 2008 Share Posted September 15, 2008 brings the girls to the yard Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4134793 Share on other sites More sharing options...
Nick378 Posted September 15, 2008 Author Share Posted September 15, 2008 brings the girls to the yard lol, it won't stay there. As soon as i know what to do, i'll replace by blue one. I just receive my order of blue silicon hose so... Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4134908 Share on other sites More sharing options...
Scadtional Posted September 15, 2008 Share Posted September 15, 2008 So.. is it ok or i should weld a nozzle on the piping to keep it like the oem one? I had the same thing and ended up tapping a nipple like the standard one. Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4135131 Share on other sites More sharing options...
discopotato03 Posted September 16, 2008 Share Posted September 16, 2008 I'll pass a few opinions on this topic which I'm sure will differ with what a lot of others think/do but hey thats life - IMO . My findings are that waste gate actuators (and solenoids) don't like getting their pressure signal from down stream of the inlet manifolds throttle/s . I had my old FJ20 like that for a while with an integral wastegate turbo (GT2860RS) and you get all sorts of silly noises and waste gate flutter from a sudden sharp pressure drop when the throttle is shut quickly . I would rather see the pressure signal line connect to the system upstream of the throttles and I'm pretty sure Nissan do this anyway in std form . When you do it this way all the waste gate diaphragm see's (via the solenoid valve) is roughly atmospheric pressure (assumes little or no pressure drop through your air filter) and up to the maximum pressure the compressor developes at wherever you tap into the system . You need to be wary of restrictions downstream of the compressor side of your turbo because if they are significant the pressure can be a fair bit higher at the turbo than it is in the inlet manifold . Corky reckons and I agree that finding a location close to the compressor housings outlet (if not in the side of it) is probably best overall . If you really wanted them you can create boost spikes by tapping in further away downstream of the compressor housing , it does this because of the time lag involved in pressurising the point further away . The down side is that the temperature rises faster at the compressor and the pressure rises faster in the turbine housing - its because the gate stays shut possibly longer because the waste gate is trying to regulate turbine/compressor speed based on pressure down stream - not at the turbocharger . IMO close to the comp housing , A . BTW you could get unusual things going on with the recirc valve if you must tap in where you have , seperate lines always ensure manifold pressure at what ever gadget thats connected to the manifold . Again I wouldn't do it this way but possibly tap into some appropriate part of the IAC housing ? I always run the most OEM style hose I can find with factory type clamps - stealth is good - defects are bad . Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4135230 Share on other sites More sharing options...
drpheel Posted September 16, 2008 Share Posted September 16, 2008 I had the same thing and ended up tapping a nipple like the standard one. +1 Worked great for me to !! Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4135262 Share on other sites More sharing options...
Nick378 Posted September 16, 2008 Author Share Posted September 16, 2008 Ok great, i'll weld a nipple to the oem place! Thanks Link to comment https://www.sau.com.au/forums/topic/236092-new-fmic-piping-vacuum-hose-pics-inside/#findComment-4135581 Share on other sites More sharing options...
