hey guys
well ive sent my wiring loom off and my link computer.. but unfortunately i cant use the link computer cause of a few different reasons.. so looking to get a power fc asap.. i saw somewhere on here that you can get them for 1000 bucks but i cant find it anymore.. so was wondering where i can get one?
also what sort am i going to need?? as its an r32 with a stagea rb25det
PLEASE HELP ME NEED ONE ASAP
ta =]
https://www.sau.com.au/forums/topic/236102-power-fc-for-rb25det/
Stock would be useless with those mods you got... :banana:
But i guess just to check everything running first , you could use stock. Or you can just go full aftermarket with a Haltech or Microtech.
Cant see why you cant use a power fc if your loom is all fine.
Im just wondering, are you the same girl that sold me your SAFCII... did we ever meet ?? like at mt ommaney ?
the tuners said not to use stock.. and naa that wasnt me who sold you that.. i dont live far from mt ommaney tho
yeah ive sent both my looms to be rewired!! i might just use the stock computer thanks sam =]
No worries Kate.
The best idea for Kate would be to get the stock ECU running for a while and if she does find a powerfc get the powerfc in there from a tuner who knows his shit.
P.S. All RB25DET powerfc's are the same. Neo's are a different story. And the looms change from model to model, obviously.
Edited by Sambo33gtst
Sam aka Dr Drift does standard computer remaps for rb25's now.
what i will be going, bit more expensive then a standard re-map as a new motherboard get put in, but still good pricing as far as i am concerned, and can do everything a PFC can do cept you dont have a hand controlller.
i'd suggest asking him, i believe he is coming up in a number of months.
so i find out this morning its a NEO engine
WTF am i supposed to effing do now???
i soo give up :happy: looks like i wont be out friday night :D
So you've got the better R34 Version of the RB25DET!!!! - Get an ER34 Power FC I guess....
Seeing its a drift car, you'll only need to run legacy items to get the car going...therefore the ER34 (R34 PFC should do the trick)????
Still....hard to get a second hand PFC for R34...well...cheap that is...
Edited by SunnyCoast
that right there is my problem :rofl:
im just gonna run my standard computer and gonna see if i can borrow a dyno on friday to check my air fuel ratio's
can anyone give me a hand with tryin to find somewhere??
would be much appreciated!!
Just to clear some things up to prevent you buying the wrong ecu
You mentioned you are using a stagea rb25det. There is a few different types. They all use R34 ecu plugs
Series 1 stagea uses a series 2 r33 rb25det and there is 3 different factory ecu's which are wired up different. Even thou they are R33 motor's the ecu plug is a R34 rb25det. Series 1 stagea's use r34 power Fc due to the plug style, but require wiring mods, depending on which model ecu you have
Series 2 stagea uses a R34 rb25det neo motor and r34 ecu plug and a r34 power fc will plug straight in and work in a stagea, your car being r32 will probably need some wiring mods. Mainly power feeds etc.
Series 2 stagea came in AWD and RWD versions with the r34 rb25det neo motor. The RWD has the traction control throtle body and the AWD version does not. This will help you determine which series 2 stagea neo motor you have.
Have a search thru the stagea section as there is few power Fc threads with the issues encounted.
Just had a look at profile and the pic's of the Rb25det.
That engine is NOT a Neo. It appears to be a r33 version.
Did it come with a AWD sump?
It did but they replaced it with the R33 sump and oil pump.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
