Aight....
Been having this misfire happening on any boost above 7psi... and it's pissing me off. It happens ALWAYS between 4000rpm and 5000rpm and only when i'm giving it some :)
I've replaced plugs about 4 times since i've had the car.... it runs fine for about a day or two then starts to misfire again.
I'm using NGK BCP6RES gapped to 0.8mm.
I've tested my coil packs las night, they ALL spark OK and all measure 0.7ohms across pins A and B.
My next question is, what ELSE could cause a misfire if it's not plugs or coils ?
  • Replies 72
Guest Robo's
Too much fuel, beleive me!!
I was like you, changing plugs in and out, coil packs, on 7psi it would slightly miss at full throttle, turn the boost up and it was terrible.
Then i got an SAFC, took some fuel out, and now she flies, no misses!!
when you say misfire, do you mean a single miss or feels like its a held choking feeling. power comes back on after 5000rpm?
if this is the case, your AFM is dodgy.
swap it with a freind's working afm and i'm betting your problem is gone.
cheers
i had the same problem, kept looking for things wrong with the motor, never thought that it was just runnning to bloody rich :O on the other hand, now its tuned its missfiring again...hmmmm
hey kym
experiencing the same prob as you, i know what it is like.
i just had my safc II installed and tuned on tuesday... didnt fix it... helped it. i have tried all avenues thatyou have except fro AFM...
i am heading to cypher on saturday where they are going to swap over a AFM for me and see if that fixes it... cross fingers... i will let you know pal
best of luck
Nate
Cheers guys,
Well, I'll just wait until the AFC is in and tuned, and if it still does it, i'll be looking at the AFM.... daym!
Maybe it's better to go for a Z32 AFM ? How much are they in comparison to a stock AFM ?
crooser,
By single misfire, i mean, it gives about 3-4 big pops consistantly between 4000rpm and 5000rpm.. then power comes back on after 5000 and it runs fine till redline...
so frustrating...
In a recent Zoom!, Martin did an article on compressor surge. The symptoms are as you describe. Occurs particularly in 'hi-flowed' turbos that are not properly matched to the engine.
The car in question was a R33 with SAFC. They retuned the SAFC for leaner fuel and more advance - it reduced the problem, but didn't totally cure it.
I've had the same thing on and off for about 14 months now. Tried diff plugs gaps etc. Have coated the coil packs with leccie tape and all sorts of things. I got a PFC and it made a "slight" improvment.
I did read on here about someone who went crazy with CRC around the packs and their area. I tried that and it worked for about a month. But its back now :)
Kym
I'd lay money on the igniter module being on the way out.
Borrow a replacement from a mate to diagnose.
Also - the ohm test of the coilpack I've never found to be reliable.
Borrow a coil pack at the same time and swap them out one by one.
Funny thing was when I was doing this, by the time I went fanging up my favourite hill for the 6th time in an hour,there was a cop at the top with a speed gun! Obviously the locals got a bit pissed off.
Originally posted by Strich9ine
Cheers guys,
crooser,
so frustrating...
Timing/spark issue mate.
The ECU retards the timing around that mark, possibly too much in your case. The coils may need a bit of a light sanding to ensure good earthing contact when they are bolted up too.
If you like come round this morning and I'll have a qiuck look if you want. (I'll PM my mobile No. and address).
Dave
bless_you,
Thanks buddy.. let me know how it goes!
blind_elk,
I have a stock turbo :D compressor surge is like you say, happens more on hi flowed turbs.
Nexus,
It still happens on yours too? what the?
Gav,
It's the seriesII engine.. so no igniter module :D just coil packs...
rev,
I've used degreaser/crc and wirebrushed/sanded back the coil packs etc.. but still to no avail...thanks for the offer, but i'll be replacing plugs today ;)
skyline33,
Done that too mate... doesnt help.. :P
st00pid cars...
if you've tried all the above, then the only thing you can do is take it to a place which has a diagnostic tool. my friend had a similar problem and took it to a place, they said the knock sensor need to be reset via the diagnostic tool.
also make sure that everything from the turbo to the airbox is on properly.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
