Anyone know of/have access too - a weight bridge somewhere in Melb?
There used to be one in Tullamarine i used to use years ago at a logistics company outside thier gate but its no longer there so that kinda sucks.
So im looking for another (as are a few mates) so we can weigh our cars and find out the actual numbers :banana:
Lemme know!
Cheers :D
https://www.sau.com.au/forums/topic/236111-weigh-bridge/
weighed a previous 1600 of mine about 10 odd years ago cnr of wellington and springy rds next to mackers on wellington rd..
not sure though if they are still there or not..
Edited by Jetdat
https://www.sau.com.au/forums/topic/236111-weigh-bridge/#findComment-4133245
Link? :D
Now i gots to look for it myself! No cookie for you!
Hrm, just rang a couple and they all want money. ($20 or so)
I want something for nothing here damnit! :banana:
theres one up wellington rd way around belgrave, ill get the address tonight, we used to go there about 2 years ago and it was open till about 10 most nights, for free!!!
https://www.sau.com.au/forums/topic/236111-weigh-bridge/#findComment-4133472
we have scales for our work commodore cup cars so you can find out the weight on all 4 corners. i'd have to ask the mech for permission though seeing as i'm not technically allowed to use the workshop (even though i do :banana:)
https://www.sau.com.au/forums/topic/236111-weigh-bridge/#findComment-4133501
Try a local tip/waste transfer station - Not sure if it is free or not.....
or
you can fool them into saying you have rubbish to dump, you then have drive up onto the scales, peer over into the office and you will see the weight of your car. :banana:
https://www.sau.com.au/forums/topic/236111-weigh-bridge/#findComment-4133793
I weigh my patrol at BP in Fitzgerald road in laverton. Cant do corners but can do axels!!
I go when its not busy, ask first and they dont charge me......or you can just drive on the weighbridge, go inside and look at the screen behind the cashiers head and it has the weights there!
https://www.sau.com.au/forums/topic/236111-weigh-bridge/#findComment-4135944
Ash, there's one in Cheltenham/Moorabbin at the Metal recyclers... i don't think they charge from memory, but if they do it would be in the $5-$10 range.
It's opposite the street that Snowy works down...
Ahhhh found it, Highett metals
http://www.highettmetal.com.au/about.html
https://www.sau.com.au/forums/topic/236111-weigh-bridge/#findComment-4141306
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
