u could try hallam tip, ready mix plant at the back, they got a weigh bridge as you drive in, dunno if its free though. theres also one on ordish road in dandy (off greens road). again, dont know if its free.
hm.. i work for the company that works at the tip, im in the clayton area working on the land fill's there,
for an easy access weigh bridge with parking would have to be Clayton Regional Public tip ... on the corner of Ryans road and Clayton road.
there is a speed hump in there but u can go around it, and there is one at the other end but just a small carpark one should be good,
Guys a bit of a prick there (brown nose) but im sure if your rock up with a decent amount of cars and get someone who is a smooth talker to bargin with him, say $5bucks each car into his pocket im sure he wont give a shit :)
  • 1 year later...
Hey East Melb guys, I found one. Didnt kno about it till last weekend, but on Burwood hwy right next to bunnings, theres a tip, and if you drive up and ask, you can get your car weighed there..its just across from
Morack road. got a friend who weighed a supra there at 1100kg, i got 1280 lol..
but yeh, just drive up. park and make sure u ask,,they do get busy
If a supra came in @ 1100kg's, then those scales are far from accurate :P
Just got back from a weigh bridge meet.
We went to one in Kilsyth, nice people there, let us negotiate to quickly run 15 cars on.. it only took 10 minutes to do.
I filled up a full tank just outside the weigh bridge so it would be easier to calculate.
Came in at 1600kg (weighbridge rounds to the nearest 20kg). So minus ~55kg for full tank, plus I have the boot stripped out, it seems about right when compared to the spec sheet (1560kg).
These are our results to the closest 20kg:
Daihatsu Sirion GTVi, 100% fuel - 900kg
Honda S2000, ~50% fuel - 1220kg
Honda Beat, ~25% fuel - 760kg
Nissan 350Z, 100% fuel - 1520kg
Nissan Pulsar Gti-R, ? fuel - 1260kg
Nissan Skyline R31, ~50% fuel - 1400kg
Nissan Skyline R34 GTR Vspec, 100% fuel - 1600kg
Nissan Skyline V35 350GT, ~50% fuel - 1560kg
Mazda MX5 soft top, ~50% fuel - 980kg
Mazda MX5 hard top, ~50% fuel - 1000kg
Mitsubishi Evo8 MR, ? fuel - 1440kg
Mazda RX7 FD3S, ~10% fuel - 1240kg
Suzuki Ignis, 100% fuel - 920kg
Toyota Celica ZR, 100% fuel - 1160kg
Toyota Soarer almost completely stripped of everything, ~30% fuel - 1420kg
Interesting list I must admit there are a couple of figures I am surprised about. R31 I would have been sure was around 1300kg.
There are a few track soarers that are into the mid 1300kg range which are only interior and sound deading removed and light weight seats. Still with stock glass and panels, they don't weigh anywhere near as much as people make out. They certainly have the capability to be reduced to 1300kg as a dedicated track car.
There is a soarer track only build currently going on and the target is 1100kg. They have plastic windows fiberglass gaurds rear quarters bonnet and boot, I don't think they will make that but I cant wait to find out where they do end up.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
