there's actually an operation atm to crack down on stolen cars, they're trying to meet a target of a number of rego checks a day. Well das what my mate who's an undercova coppa told me.
Remember guys, its only the traffic cops we hate...
I spoke to a mate who's a cop and he said he was only ever in a bad mood when doing traffic shit. Not to mention he's beaten most of my speed records :D
Originally posted by Champinco
hey nismoid,
were u in tullamarine on wednesday? turning on to the freeway (towards city) from mickleham rd? at about 6ish? i think i saw u once again
nah. the car is @ the mrs ATM. i got no license lol!
so she is driving the beast to keep it running.
Plus her chev is getting air bags :D
but yes. ONLY the road/traffic coppers i have a problem with.
Other members like the ones that sort out domestics and all the other things are totally reasonable and level headed.
I got 'chased' down the road at 50km/h by a copper who also told me that my exhaust was too loud, and I needed a EPA test and had to hand in the result within the next 28 days!
I saved him the trouble and pulled out a piece of paper from the glove-box... an EPA test they did on my car with I got the exhaust fixed 15 mins earlier in Box Hill! :D
They just have bad days... get sh!tty 'cause they get traffic duty, and pick on ppl... not to worry!
:bahaha: what did he say to that one? :D
I think if you've previously had an EPA test its a good idea to carry the results around. Even if legally they hold no ground the second they are done, its a pretty dickhead copper that goes and puts you in again just after having being cleared. They can, but well there are grounds for complaint if they keep trying to dobb you in when its fairly clear you're not over the limit.
he asked me how long it took to do on my computer...
I politely asked him to come back to the garage with me if he thought it was a fake and to ask the person that did the test for me :)
I then basically through the results back in the drivers window and went back to his car, says not another word.
the good ol' "Have a nice day" must only be reserved for when they give you a ticket and know your day is going to be crap!
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
