Hi Guys,
Back again. Had to make a new membership becuase my old one is really screwed up.
I just wanted to let you know that in relation to the topic of discussion that generated so many posts before, my R34 GTT also managed to finally lock into 3rd gear.
Rather than re-wire Solenoid B, which is one of the designated fault sources for this problem, I managed to source a Nissan shift solenoid kit from Nissan Australia. Specifically, from their dealership at Burwood.
The cost.................$449.
The install...............$350.
The car now runs as it should.
I will post the part number for the shift solenoid kit shortly.
Regards
Jim (TR34GT)
https://www.sau.com.au/forums/topic/236129-r34-gtt-auto-trans-problems/
Hi Guys,
Regards
Jim (TR34GT)
The part Number is: 319404AX05
Good to hear you got it sorted, it's damn annoying when it happens!
Hey 666DAN,
Thanks mate. It was a long process. Would you believe that it was only the guys in South Australia, MV Automatics, who had faith in the solenoid re-wiring. I couldn't get anyone to re-wire where I live. The guys here had no experience in this regard. I can thoroughly recommend getting hold of the full solenoid kit though. You were right. It was the solenoids after all. Glad I took the chance, as right up to the end, my autotrans (specialists) could not read the fault code, even when I brought the car to them with the fault still in place.
By the way, the $40 induction box we made still works a treat.
Watch this space for the answer to the negative camber adjustment on my car as well as a performance tyre at the right price.
Hope all is well. Regards
Jim (TR34GT)
Thanks for the follow up mate.. it's great when members are able to come back and tell us how they went.
Hey Howie.
Just wanted to let you know that the part number mentioned was definitely right.
The wrong part number was ordered twice yb different autotrans specialists, until I found the right people to speak to at Nissan.
Hope all is well, and the white R34 in the pic looks great.
Regards
Jim (TR34GT)
Hey Howie.
Regards
Jim (TR34GT)
Picture of solenoid kit attached
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
