Hi there guys I have some r32 GTR parts up for sale after tossing in my project.So here go's
RB26 Head complete with manifolds,throttle bodies covers,front cover,no igniter or injectors they come separate $1,400 Delivered or $1,300 pick up
Injectors $240 delivered
Complete engine harness $270 delivered
Ignitor $100 delivered
Pair of air flow meters $100 delivered
Blow off valves $120 delivered
Computer $170 delivered
PM if interested
post-41975-1221449616_thumb.jpgpost-41975-1221450919_thumb.jpgpost-12959-1124435778.jpgpost-41975-1221452438_thumb.jpg
https://www.sau.com.au/forums/topic/236135-rb-26-parts/
Injectors sold
PM if interested
https://www.sau.com.au/forums/topic/236135-rb-26-parts/#findComment-4140167
Buyer Beware.
This is how my injectors rocked up. All 6 totalled due to awful packing. Before people go on about it being Aus post's fault how would you expect six injectors floating around with no padding in a plastic lunchbox to arrive.post-32162-1221873253_thumb.jpg
https://www.sau.com.au/forums/topic/236135-rb-26-parts/#findComment-4144425
Buyer Beware.
Guys this guy is a joke he asks me to send injectors I package them in a CONTAINER with BUBBLE wrap both around injectors and around container I put into a express post satchel as I'm requested by buyer then send.They then arrive and it looks like someone has stood on item.He has demanded return of money and I have told him to take it up with AUS post.As much as I feel SORRY for the guy I believe it is outrageous that he can come on here and do this when it is CLEARLY AUS posts fault.
https://www.sau.com.au/forums/topic/236135-rb-26-parts/#findComment-4144455
Bubble wrap hey... where exactly? There's not one shred of bubble wrap in the package I opened yesterday. That picture shows exactly how the injectors arrived.
https://www.sau.com.au/forums/topic/236135-rb-26-parts/#findComment-4144460
Don't talk crap they had little BUBBLE wrap sleeves around them and wrap around container,ONCE again I cannot be blamed for AUS post.I don't think there is someone on this forum who has not had a problem with AUS post,thats why they have insurance.I feel bad for you man but as I said take it up with AUS post.Just lastley MODS I think it is very POOR of someone to try to wreck ones sale thread thru no fault of there own.So I think he would be better of taking his understandable displeasure up with the ones to blame AUS post and not trashing a honest guy who did all I could
Cheers
https://www.sau.com.au/forums/topic/236135-rb-26-parts/#findComment-4144469
Here's a photo of all the packaging including the free floating lunchbox you sent the injectors in.
I must say you have awesome dispute resolution too. Call me a tosser and make up imaginary bubble wrap. Can you tell me where the bubble wrap is in this photo? Or are you mistaking the brown PAPER wrapped around the outside of your lunchbox?
I post in this thread simply as a warning of my experience with this seller.
For the record I have taken these to Australia Post. They have a clause about packing things securely apparently.
As to you being honest. I can post all my correspondence from you up til now. The bubble wrap was only invented in the last 3 or 4 emails.
Regards,
Javan
Cheers
https://www.sau.com.au/forums/topic/236135-rb-26-parts/#findComment-4144490
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
