WREAKING R32 GT-R. :)
all panels available, complete interior, engine, gearbox, ecu, shell, suspension. All parts avilable.
Also HKS Hyoer exhaust with twin stainless engine pipe,
Multi-plate Nismo G-Max clutch,
18" Blitz rims and good tyres,
Twin Blitz bolt on blow off valves.
Ring if your interested, 0419118258
https://www.sau.com.au/forums/topic/23615-r32-gt-r-bits/
Ok
Steering wheel, $250 Excellent cond.
Exhaust, Cat back $750, front pipes $450
Struts, duno if they are stock, they are silver with GTR
stickers on them, but they are stock height $500
Nismo G-Max2 Twin plate clutch, $1800 worth $3200 new
Blitz Twin BOVs, new style $800 pair wth pipe
Cusco saftey 21 roll cage, 6 point $850
Bride racing seat suit R32 or R33 $600
Will take offers on those prices.. Ring if interested 0419118258
https://www.sau.com.au/forums/topic/23615-r32-gt-r-bits/#findComment-510157
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
