  • Replies 124
Posted Images
Ryan, can you adjust camber on the front coils on all models? How is this done? I bought my car with the coils and received no instruction from the guy i bought it from.
Hi, Camber on skylines is done via the upper controll arm not the coilover camber top like like silvia/mazda/subaru etc. I'am using whiteline bushes in my skyline at the moment but we can also order in adjustable section/silk road/cusco arms for you.
Ryan
Looking to buy a new set of coil overs for my 32 gtst coz my rear ones have shite themselves.
What's everyone's opinion on brands????
i have ISC's, they work great! but had the biggest f**k around with customer service getting them, it was horrible. Had to exchange the rear coilovers twice to get the correct ones.
Bilstein approx $2500 is the cheapest I've seen..........and that's only shocks & springs, you have to use the top hats and rubbers from your stock coilovers.
?? i paid under $1500 for mine, i have nfi where ur getting ur figures from.
for the street maybe 4.5kg/3.5kg, for track around the 6/4kg mark.
erm aren't R33's standard springs about the 4kg up front not sure of rear prolly 3kg and i know your talking R32 but hey doesnt matter what model you would use similar rates across the board
also Pete got proper Bilstein coil overs not a spring and shocker combo
im thinking of changing my springs from 12fr 10rr to 8fr and 7rr
Lawson - i dunno why you found Ryan's service to be sub par but i found it impeccable, unless you didn't deal with Ryan ?? or you didn't give him all the information he needed to sort you out efficiently
steve, from what i saw from the pics of the isc coilovers, i think that they were trying to make universal style ones and the rear shock shafts were alot longer then they needed to be making it not be able to lower much past stock hight as 32's needed to have the smaller shocks.
although, i had a small problem with a product from them and when i told him he was happy to exchange the product and even brought it himself to the workshop. i was happy with the customer service!
Steve, you could even go softer since your car is 90% street use.
Probably even 6 or 7 Front & 5 or 6 Rear...............wouldn't go any softer just in case you wanted to do track work.
Been speaking alot to SK, his son Matt and Poly Air Springs in NSW lately.......they are all experts when it comes to spring rates and all agree with the above info as long as you stiffen up the sway bars.
Japs, according to Matt, tend to favour the very hard coilover and don't worry about their sway bars.
He says it may have something to do with their very narrow carports, garages & driveways, lol
not for a GTR bud.........try double that
I spoke to Gary & his son Matt twice this week already and that price I quoted is probably on the light side
once again, we are talking about an R32 GTS-t. not 100% how u talking about ur R34 GTR is relevant here.
pretty sure the stock springs are around 3kg all round, the whiteline group buy uses springs which are around 3.5kg all round for the street. the main issue with stock suspension is in the dampers, not so much the springs. there is no real need to go very high rates on the street, with decent sway bars u will have more than enough roll control for street conditions. going high rates will only mean a rougher ride and reduced traction.
the spring/shocker combo u refer to are no less coilovers than any other suspension u can buy, the only difference between them and what people generally refer to as coilovers are they have thread adjustable lower seats rather than using circlips. if u dont plan on changing the ride height more than once every few months then u will never even know the difference.
btw i run the bilstein/eibach combo with the "coilover conversion kit", 6/4kg, that ended up costing around $2200ish. i bought these to suit the track, i wouldnt have bothered with them if my car didnt see a lot of track work.
ah cool :)
yeah Pete want to do a little track work but i could put the 12/10kg back in yeah??
so i guess a 6/5kg would be ideal with stiffer sway bars and if i went on track with the 12/10kg then soften up the sway bar a little ?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
