  • Replies 124
Posted Images
I got kei-office 8KG/6KG... their pretty good, would reccomend them but make sure you get the damper adjustment tool with them, cos you cant change the damper in the rear with out it..
Edited by DemsA31
Hey mate
My friend bought ISC coilovers for his 4dr 32 and is very happy with results.
He has spent a lot of money on ISC branded products and never has issues.
ATM i have king springs and will be definitely looking to get ISC coilovers in the future.
$1500 for the set isnt to much of a bite out the wallet for good results. :dry:
http://www.isc-coilovers.com/
here is the site go check it out.
Ryan is based in Adelaide
Non N1- "This coilover is currently only available for S13/S14/S15, Mazda FC and WRX. It is basically the same spec as our N1 coilover except this model comes without pillowball/camper tops on the front coilovers. Instead the cambere top is replaced with a non adjustable strut top. Camber on the front can still be adjusted via an enlongated hole in the bottom bracket."
Quick question... how do u know when your coil overs have shat themselves???
cuz mine are bumpy as anything... kinda giving me the shits now
came with the car from japan... they are blue but no idea wot brand they are
i know they are adjustables if that helps..
ISC N1 coilovers = $1499. These are 32 step damper adjustable and unlike alot of the "jap" ones ISC are base height adjustable. The difference between the ISC N1 and the basics is the front pillowballs, the N1's have them and the basics do not. Pillowballs are there for better steering response allowing the top of the strut to move around when cornering etc. ISC coilovers are SA based and we pride ourselves on our customer service!
If anyone has any questions please don't hesitate to throw me a pm,Ryan
Edited by ISC-Performance
The most common blue coilover to come out of japan would be Cusco. Have you checked for leaks etc? Could also be worn pillowballs at the top of the strut, siezed shock etc.
Ryan
I'm pretty sure my springs are 5kg/4kg...gonna see If I can dig up my original receipts...
that'll be good if you can find out.
My Bilsteins are 400lb (7kg) at the front & 450lb (8kg) at the rear.
I wouldn't mind going a bit softer on the rears though, maybe 5 or 6kg.
I was just talking to Matt (SK's son) who said that is way too stiff Luke. They recommend about 5 or 6 on the front and 4 or 5 on the rear with heavy sway bars to compensate........unless your vehicle is mainly used for track.
Spoke to Polyair Suspension in Sydney today, who are very knowledgeable about damping rates, and they said that even though Jap stuff have either 16 or 32 steps of adjustment, the difference between the softest setting and the hardest is not as great as a European shocker with only 9 settings..........go figure?!
i can personally vouch for Ryans customer service :down:
yeah Luke we need GTR front sway bars you may also need GTR rear but for me its GTSt in the rear
it was my understanding the ISC only do the N1 here no point doing the cheapies
have tein hr in mine with 35mm cusco sway bars. depending on the rd they can be harsh but generally they are good. no body roll but yet the way they are set there is still plenty of movement for general driving.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
