  • Replies 124
Posted Images
Ryan, can you adjust camber on the front coils on all models? How is this done? I bought my car with the coils and received no instruction from the guy i bought it from.
Hi, Camber on skylines is done via the upper controll arm not the coilover camber top like like silvia/mazda/subaru etc. I'am using whiteline bushes in my skyline at the moment but we can also order in adjustable section/silk road/cusco arms for you.
Ryan
Looking to buy a new set of coil overs for my 32 gtst coz my rear ones have shite themselves.
What's everyone's opinion on brands????
i have ISC's, they work great! but had the biggest f**k around with customer service getting them, it was horrible. Had to exchange the rear coilovers twice to get the correct ones.
Bilstein approx $2500 is the cheapest I've seen..........and that's only shocks & springs, you have to use the top hats and rubbers from your stock coilovers.
?? i paid under $1500 for mine, i have nfi where ur getting ur figures from.
for the street maybe 4.5kg/3.5kg, for track around the 6/4kg mark.
erm aren't R33's standard springs about the 4kg up front not sure of rear prolly 3kg and i know your talking R32 but hey doesnt matter what model you would use similar rates across the board
also Pete got proper Bilstein coil overs not a spring and shocker combo
im thinking of changing my springs from 12fr 10rr to 8fr and 7rr
Lawson - i dunno why you found Ryan's service to be sub par but i found it impeccable, unless you didn't deal with Ryan ?? or you didn't give him all the information he needed to sort you out efficiently
steve, from what i saw from the pics of the isc coilovers, i think that they were trying to make universal style ones and the rear shock shafts were alot longer then they needed to be making it not be able to lower much past stock hight as 32's needed to have the smaller shocks.
although, i had a small problem with a product from them and when i told him he was happy to exchange the product and even brought it himself to the workshop. i was happy with the customer service!
Steve, you could even go softer since your car is 90% street use.
Probably even 6 or 7 Front & 5 or 6 Rear...............wouldn't go any softer just in case you wanted to do track work.
Been speaking alot to SK, his son Matt and Poly Air Springs in NSW lately.......they are all experts when it comes to spring rates and all agree with the above info as long as you stiffen up the sway bars.
Japs, according to Matt, tend to favour the very hard coilover and don't worry about their sway bars.
He says it may have something to do with their very narrow carports, garages & driveways, lol
not for a GTR bud.........try double that
I spoke to Gary & his son Matt twice this week already and that price I quoted is probably on the light side
once again, we are talking about an R32 GTS-t. not 100% how u talking about ur R34 GTR is relevant here.
pretty sure the stock springs are around 3kg all round, the whiteline group buy uses springs which are around 3.5kg all round for the street. the main issue with stock suspension is in the dampers, not so much the springs. there is no real need to go very high rates on the street, with decent sway bars u will have more than enough roll control for street conditions. going high rates will only mean a rougher ride and reduced traction.
the spring/shocker combo u refer to are no less coilovers than any other suspension u can buy, the only difference between them and what people generally refer to as coilovers are they have thread adjustable lower seats rather than using circlips. if u dont plan on changing the ride height more than once every few months then u will never even know the difference.
btw i run the bilstein/eibach combo with the "coilover conversion kit", 6/4kg, that ended up costing around $2200ish. i bought these to suit the track, i wouldnt have bothered with them if my car didnt see a lot of track work.
ah cool :)
yeah Pete want to do a little track work but i could put the 12/10kg back in yeah??
so i guess a 6/5kg would be ideal with stiffer sway bars and if i went on track with the 12/10kg then soften up the sway bar a little ?
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
